Printing to PDF in MYOB using Adobe Acrobat X1 Pro
Mar 07, 2018 Mar 07, 2018
Hi there,  I have just upgraded MYOB to the latest version 2017.2.0.  When I try to print invoices to PDF, the result is blurry and unclear text.  Even the free PDF writers do a better job than the Adobe Acrobat version I have paid for.  I have contacted MYOB support but they are saying it is an issue with my PDF writer.  When the invoices are emailed it comes out clearly - MYOB says that this is because the emailing feature uses MYOB's built in PDF writer but printing to PDF does not.  I have also tried "Sending" it to "disk" with the same blurred result.  Surely Adobe can do a better job of PDFs than MYOB.  Am I missing something here?  Going crazy trying to sort this .......... hope someone can help
General troubleshooting
526
What is MYOB?
MYOB is a very common accounting package
Jannine
Sent from my SAMSUNG Galaxy S7 on the Telstra Mobile Network
Mar 08, 2018 Mar 08, 2018
I am not familiar with that application, so I cannot comment on how it creates PDF files. In general, if the application does have a built-in PDF generator, you should be able to also save the PDF files directly, without the need to print to PDF. Printing to PDF usually creates lower quality PDF files because your page content first has to be converted to PostScript, and that PostScript then gets converted to PDF. Lower quality in this context has nothing to do with resolution, so that alone should not be the cause for the fuzziness you are seeing. This is usually caused by using the wrong PDF conversion settings. This is something you can select when you use the "Adobe PDF" printer. It is possible that you have the output resolution set too low. See here for more information about how to change this:
Adobe PDF conversion settings, Acrobat
