Help! I have a new laptop, just downloaded the trial version of Lr, trying to tether or set up the wi fi connection for shooting.
I have done all the steps in the how tos, it just says no camera detected, I have it plugged in with a tether cord. Restarts, turning it off and on, etc, just not detected.gives me message the
On the wi fi I enter the password for my wi fi and it just sits there
[Moved from LRCC to LR Classic - moderator]
Not sure that you can shoot tethered in the trial version... investigating that.
I was using the trial to see if I could use this on this laptop. You think I have to sign up and pay to find out?
If your laptop is new and you're running current versions of software across the board tethering shouldn't be a problem. I shoot tethered to my laptop without any issues... Nikon D810, Macbook Pro 2017, 16 GB RAM...
If you've followed the steps below and can't select your camera it is likely that this feature isn't offered in the 7-day trial version.
Steps to tether EOS 6D in to Lightroom
Do you have a card in the camera?
yes, I can take it out, I took it out at one point and nothing changed.
Try the steps in the link to see if any of these will work.
Fix tethered shooting in Lightroom
*Especially making sure your camera's firmware is up to date!
I updated the firmware, still not recognizing that a camera is attached. I think I should give up.
Which version of the Lightroom trial did you download? Does it have a gray border or a cyan border around the badge?
If it is the cyan (bright blue) border (on the right) you will not be able to tether:
https://tethertalk.com/2017/11/13/tethering-in-lightroom-cc-vs-lightroom-classic-cc/
You will need to install the trial version of Classic
I keep trying to set up the wi fi on the camera, I entered my wi fi pass and now it says pairing in progress, Start pairing software on computer, if it is not already running. I have lightroom open, and tethered capture open. Is there something else?
I've also just tried it with a tether cord and the lightroom doesn't see a camera.
