Hi.
I just installed Photoshop CC 2018 and it takes an age to load up. I reinstalled 2017 and it takes 9 secs to load. 2018 takes 40 secs - longer if I am in Lightroom and use 'edit in' - over a minute to get it loaded and ready to use. 2017 takes about 12 secs.
Neither is particularly speedy - anyone have this issue ? Any solutions ?
MY PC is very high spec - Asus Rampage VI, 500GB M.2 SSD with the Opsys and Apps loaded, I9 7900 processor, liquid cooled and overclocked to 4.5GHz, Asus Strix 1070 GTX Graphics card, and 64GB of fast RAM. Surely it should be better than this ??? I am using Windows 10 Pro 64 - all up to date with latest drivers ( including graphics card from NVidia ).
Tried disabling Graphics acceleration and it made no difference. Also selected an alternative scratch disc and no change there either.
Other apps load almost instantly. ( Proshow, Office etc )
Any ideas, suggestions gratefully received.
40 seconds seems like a long time. How long it take for Photoshop to load and inialize varies it depends on many factors. Processor speed, Storage speed, RAM seed Photoshop version and Photoshop add ons. I just timed CC 2018 on me machine. Did two test. I removed all may add ons and removed all my Photoshop User ID CC 2018 data. I started CC 2018 and let it build all new default user id data foe cc 2018 closed down Photoshop. I started a stopwatch and cc 2018 it took 16.612sec for it to be up and ready. I closed CC 2018 and deleted all the new user id date for CC 2018. I then restored my Old user id data. Added my Photoshop Add-ons back into my Photoshop install Stated a stopwatch and CC 2018 This time it took 23.839sec for Photoshop to be up and ready. 44% longer than without add-ons. About half the time it takes your machine which is a much faster machine than mine. My machine is only a 2GHZ machine and my high speed Ram is clocked slower because of my processors slower clock speed. I could see CC 2018 with no add-ons on your machine could take as little as 7sec to start on your. 40 sec would be 573% slower. I'm posting my CC 2018 System Info compare your to it see if you see anything odd in yours.
Adobe Photoshop Version: 19.1.1 20180206.r.254 2018/02/06: 1156206 x64
Number of Launches: 54
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.15
System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Physical processor count: 12
Logical processor count: 24
Processor speed: 1995 MHz
Built-in memory: 40886 MB
Free memory: 2 MB
Memory available to Photoshop: 36915 MB
Memory used by Photoshop: 90 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=-1920, bottom=1080, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA Quadro 4000"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="21.21.13.7755"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
glgpu[0].GLRendererID=1757
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvd3dumx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvwgf2umx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvwgf2umx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvwgf2umx.dll"
glgpu[0].GLDriverDate="20170713000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.1 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="Quadro 4000"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="377.55"
clgpu[0].CLBandwidth=7.48219e+10
clgpu[0].CLCompute=191.705
License Type: Subscription
Serial number: 90970090970448917498
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\jjmac\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 224.2G, 111.9G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/11/22-18:28:12 79.589342 79.589342
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2017/10/31-06:12:59 79.250229 79.250229
AdobePIP.dll Adobe Product Improvement Program 7.4.1.109.46827
AdobeSVGAGM.dll AdobeSVGAGM 79.588619 79.588619
AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/11/22-18:28:12 79.589342 79.589342
ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000
ARE.dll ARE 2017/11/22-18:28:12 79.589342 79.589342
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/11/22-18:28:12 79.589342 79.589342
BIBUtils.dll BIBUtils 2017/11/22-18:28:12 79.589342 79.589342
boost_date_time.dll photoshopdva 11.1.0
boost_filesystem.dll photoshopdva 11.1.0
boost_signals.dll photoshopdva 11.1.0
boost_system.dll photoshopdva 11.1.0
boost_threads.dll photoshopdva 11.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/11/22-18:28:12 79.589342 79.589342
CRClient.dll Adobe Crash Reporter Client DLL 1.6.3.0
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 11.1.0
dvacore.dll photoshopdva 11.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 11.1.0
dvamediatypes.dll photoshopdva 11.1.0
dvametadata.dll photoshopdva 11.1.0
dvametadataapi.dll photoshopdva 11.1.0
dvametadataui.dll photoshopdva 11.1.0
dvaplayer.dll photoshopdva 11.1.0
dvatransport.dll photoshopdva 11.1.0
dvaui.dll photoshopdva 11.1.0
dvaunittesting.dll photoshopdva 11.1.0
dynamiclink.dll photoshopdva 11.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1150526 81.1150526
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.22
JP2KLib.dll JP2KLib 2017/10/31-01:22:04 79.268591 79.268591
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
LogSession.dll LogSession 7.4.1.109.46827
mediacoreif.dll photoshopdva 11.1.0
MPS.dll MPS 2017/10/31-01:22:04 79.588396 79.588396
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2018 19.1.1
Plugin.dll Adobe Photoshop CC 2018 19.1.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.5.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.5.0.87
PSArt.dll Adobe Photoshop CC 2018 19.1.1
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.1.1
SCCore.dll ScCore 2017/08/31-12:13:14 81.1150526 81.1150526
SVGRE.dll SVGRE 79.586793 79.586793
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WinRTSupport.dll Adobe Photoshop Windows RT Support 19.0.0.0
WRServices.dll WRServices Thu June 21 2017 12:26:24 Build 0.22473 0.22473
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Accented Edges 19.1.1 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 19.1.1 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 19.1.1 - from the file “Filter Gallery.8bf”
Average 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Average.8bf”
Bas Relief 19.1.1 - from the file “Filter Gallery.8bf”
BMP 19.1.1 - from the file “Standard MultiPlugin.8bf”
Camera Raw 10.2 - from the file “Camera Raw.8bi”
Camera Raw Filter 10.2 - from the file “Camera Raw.8bi”
Chalk && Charcoal 19.1.1 - from the file “Filter Gallery.8bf”
Chrome 19.1.1 - from the file “Filter Gallery.8bf”
Cineon 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Cineon.8bi”
Clouds 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Clouds.8bf”
Collada 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Color Halftone 19.1.1 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 19.1.1 - from the file “Filter Gallery.8bf”
CompuServe GIF 19.1.1 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 19.1.1 - from the file “Filter Gallery.8bf”
Craquelure 19.1.1 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 19.1.1 - from the file “Standard MultiPlugin.8bf”
Crosshatch 19.1.1 - from the file “Filter Gallery.8bf”
Crystallize 19.1.1 - from the file “Standard MultiPlugin.8bf”
Cutout 19.1.1 - from the file “Filter Gallery.8bf”
Dark Strokes 19.1.1 - from the file “Filter Gallery.8bf”
De-Interlace 19.1.1 - from the file “Standard MultiPlugin.8bf”
Dicom 19.1.1 - from the file “Dicom.8bi”
Difference Clouds 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Clouds.8bf”
Diffuse Glow 19.1.1 - from the file “Filter Gallery.8bf”
Displace 19.1.1 - from the file “Standard MultiPlugin.8bf”
Dry Brush 19.1.1 - from the file “Filter Gallery.8bf”
Eazel Acquire 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “EazelAcquire.8ba”
Entropy 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Export Color Lookup Tables 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Export3DLUT.8be”
Extrude 19.1.1 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “FastCore.8bx”
Fibers 19.1.1 - from the file “Standard MultiPlugin.8bf”
Film Grain 19.1.1 - from the file “Filter Gallery.8bf”
Filter Gallery 19.1.1 - from the file “Filter Gallery.8bf”
Flash 3D 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Fresco 19.1.1 - from the file “Filter Gallery.8bf”
Glass 19.1.1 - from the file “Filter Gallery.8bf”
Glowing Edges 19.1.1 - from the file “Filter Gallery.8bf”
Google Earth 4 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Graphic Pen 19.1.1 - from the file “Filter Gallery.8bf”
Halftone Pattern 19.1.1 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 19.1.1 - from the file “HDRMergeUI.8bf”
HSB/HSL 19.1.1 - from the file “Standard MultiPlugin.8bf”
IFF Format 19.1.1 - from the file “Standard MultiPlugin.8bf”
IGES 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Ink Outlines 19.1.1 - from the file “Filter Gallery.8bf”
JPEG 2000 19.1.1 - from the file “JPEG2000.8bi”
Kurtosis 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Lens Blur 19.1.1 - from the file “Lens Blur.8bf”
Lens Correction 19.1.1 - from the file “Lens Correction.8bf”
Lens Flare 19.1.1 - from the file “Standard MultiPlugin.8bf”
Liquify 19.1.1 - from the file “Liquify.8bf”
Matlab Operation 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “ChannelPort.8bf”
Maximum 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Mean 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Measurement Core 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “MeasurementCore.8me”
Median 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Mezzotint 19.1.1 - from the file “Standard MultiPlugin.8bf”
Minimum 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
MMXCore Routines 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “MMXCore.8bx”
Mosaic Tiles 19.1.1 - from the file “Filter Gallery.8bf”
Multiprocessor Support 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “MultiProcessor Support.8bx”
Neon Glow 19.1.1 - from the file “Filter Gallery.8bf”
Note Paper 19.1.1 - from the file “Filter Gallery.8bf”
NTSC Colors 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “NTSC Colors.8bf”
Ocean Ripple 19.1.1 - from the file “Filter Gallery.8bf”
OpenEXR 19.1.1 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 19.1.1 - from the file “Filter Gallery.8bf”
Palette Knife 19.1.1 - from the file “Filter Gallery.8bf”
Patchwork 19.1.1 - from the file “Filter Gallery.8bf”
Paths to Illustrator 19.1.1 - from the file “Standard MultiPlugin.8bf”
PCX 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “PCX.8bi”
Photocopy 19.1.1 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 19.0 - from the file “PSDX.8bi”
Picture Package Filter 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “ChannelPort.8bf”
Pinch 19.1.1 - from the file “Standard MultiPlugin.8bf”
Pixar 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Pixar.8bi”
Plaster 19.1.1 - from the file “Filter Gallery.8bf”
Plastic Wrap 19.1.1 - from the file “Filter Gallery.8bf”
PLY 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Pointillize 19.1.1 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 19.1.1 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “PBM.8bi”
Poster Edges 19.1.1 - from the file “Filter Gallery.8bf”
PRC 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Radial Blur 19.1.1 - from the file “Standard MultiPlugin.8bf”
Radiance 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Radiance.8bi”
Range 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Render Color Lookup Grid 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Export3DLUT.8be”
Reticulation 19.1.1 - from the file “Filter Gallery.8bf”
Ripple 19.1.1 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 19.1.1 - from the file “Filter Gallery.8bf”
Save for Web 19.1.1 - from the file “Save for Web.8be”
ScriptingSupport 19.1.1 - from the file “ScriptingSupport.8li”
Shake Reduction 19.1.1 - from the file “Shake Reduction.8bf”
Shear 19.1.1 - from the file “Standard MultiPlugin.8bf”
Skewness 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Smart Blur 19.1.1 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 19.1.1 - from the file “Filter Gallery.8bf”
Solarize 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Solarize.8bf”
Spaces 19.1.1 - from the file “Spaces.8li”
Spatter 19.1.1 - from the file “Filter Gallery.8bf”
Spherize 19.1.1 - from the file “Standard MultiPlugin.8bf”
Sponge 19.1.1 - from the file “Filter Gallery.8bf”
Sprayed Strokes 19.1.1 - from the file “Filter Gallery.8bf”
Stained Glass 19.1.1 - from the file “Filter Gallery.8bf”
Stamp 19.1.1 - from the file “Filter Gallery.8bf”
Standard Deviation 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
STL 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Sumi-e 19.1.1 - from the file “Filter Gallery.8bf”
Summation 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Targa 19.1.1 - from the file “Standard MultiPlugin.8bf”
Texturizer 19.1.1 - from the file “Filter Gallery.8bf”
Tiles 19.1.1 - from the file “Standard MultiPlugin.8bf”
Torn Edges 19.1.1 - from the file “Filter Gallery.8bf”
Twirl 19.1.1 - from the file “Standard MultiPlugin.8bf”
U3D 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Underpainting 19.1.1 - from the file “Filter Gallery.8bf”
Vanishing Point 19.1.1 - from the file “VanishingPoint.8bf”
Variance 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
Water Paper 19.1.1 - from the file “Filter Gallery.8bf”
Watercolor 19.1.1 - from the file “Filter Gallery.8bf”
Wave 19.1.1 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi”
WIA Support 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “WIASupport.8li”
Wind 19.1.1 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “WBMP.8bi”
ZigZag 19.1.1 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
CUR (Windows Cursor) NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
Face Control II 2.00 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FaceControl(X64).8bf”
Fine Touch 3.25 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FineTouch(X64).8bf”
GREYCstoration NO VERSION - from the file “C:\Photoshop64 Plug-Ins\GreycShop_x64_LAA_2013-08-04\Greyc-x64.8bf”
ICO Windows Icon/Favicon NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
Import from FastPictureViewer Codec Pack 3.8.0.96 - from the file “C:\Photoshop64 Plug-Ins\FastPictureViewerCodecPack\FastPictureViewerCodecPack.PhotoshopImport64.8ba”
JPEG XR 1, 1, 0, 0 - from the file “C:\Photoshop64 Plug-Ins\Microsoft\JPEGXR_x64.8bi”
Lazy Nezumi Pro 18.01.01.0038 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\MouseHookPro64.8li”
Luce NO VERSION - from the file “C:\Photoshop64 Plug-Ins\Luce2_64\luce_64.8bf”
Reduce Noise v8 8.0.1.0 - from the file “C:\Photoshop64 Plug-Ins\NeatImage8\NeatImage8.8bf”
ScriptListener 13.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\ScriptListener.8li”
SGI RGB 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) - from the file “C:\Photoshop64 Plug-Ins\SGIRGB\SGIRGB.8BI”
StarFilter Pro 3 3.0.5.1 - from the file “C:\Photoshop64 Plug-Ins\ProDigitalSoftware\StarFilterPro3X64.8bf”
SuperPNG 2.0 - from the file “C:\Photoshop64 Plug-Ins\SuperPNG\SuperPNG.8bi”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
com.adobe.Butler.backend 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
Libraries 2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
New Document 2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html”
Start 2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html”
SVG Layers 1.0.0 - from the file “C:\Users\jjmac\AppData\Roaming\Adobe\CEP\extensions\SVGLayers\index.html”
Export As 3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
JSX Launcher 0.1.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\net.sytes.chuwa.jsxlauncher\index.html”
Installed TWAIN devices: NONE
Adobe Photoshop Version: 19.1.1 20180206.r.254 2018/02/06: 1156206 x64Number of Launches: 54Operating System: Windows 10 64-bitVersion: 10 or greater 10.0.16299.15System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreadingPhysical processor count: 12Logical processor count: 24Processor speed: 1995 MHzBuilt-in memory: 40886 MBFree memory: 2 MBMemory available to Photoshop: 36915 MBMemory used by Photoshop: 70 %Alias Layers: Disabled.Modifier Palette: Disabled.Highbeam: Enabled.Image tile size: 1024KImage cache levels: 4Font Preview: MediumTextComposer: LatinDisplay: 1Display Bounds: top=0, left=0, bottom=1080, right=1920Display: 2Display Bounds: top=0, left=-1920, bottom=1080, right=0OpenGL Drawing: Enabled.OpenGL Allow Old GPUs: Not Detected.OpenGL Drawing Mode: AdvancedOpenGL Allow Normal Mode: True.OpenGL Allow Advanced Mode: True.AIFCoreInitialized=1AIFOGLInitialized=1OGLContextCreated=1NumGLGPUs=1NumCLGPUs=1NumNativeGPUs=0glgpu[0].GLVersion="4.1"glgpu[0].IsIntegratedGLGPU=0glgpu[0].GLMemoryMB=2048glgpu[0].GLName="NVIDIA Quadro 4000"glgpu[0].GLVendor="NVIDIA Corporation"glgpu[0].GLVendorID=4318glgpu[0].GLDriverVersion="21.21.13.7755"glgpu[0].GLRectTextureSize=16384glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"glgpu[0].GLRendererID=1757glgpu[0].HasGLNPOTSupport=1glgpu[0].GLDriver="C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvd3dumx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvwgf2umx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvwgf2umx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvwgf2umx.dll"glgpu[0].GLDriverDate="20170713000000.000000-000"glgpu[0].CanCompileProgramGLSL=1glgpu[0].GLFrameBufferOK=1glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1clgpu[0].CLPlatformVersion="1.2"clgpu[0].CLDeviceVersion="1.1 CUDA"clgpu[0].IsIntegratedCLGPU=0clgpu[0].CLMemoryMB=2048clgpu[0].CLName="Quadro 4000"clgpu[0].CLVendor="NVIDIA Corporation"clgpu[0].CLVendorID=4318clgpu[0].CLDriverVersion="377.55"clgpu[0].CLBandwidth=7.48219e+10clgpu[0].CLCompute=191.705License Type: SubscriptionSerial number: 90970090970448917498GUIDBucket:Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Temporary file path: C:\Users\jjmac\AppData\Local\Temp\Photoshop scratch has async I/O enabledScratch volume(s): Startup, 224.2G, 111.9G freeRequired Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components: A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112 ACE.dll ACE 2017/11/22-18:28:12 79.589342 79.589342 AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146 AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0 AdobeOwl.dll Adobe Owl 5.2.11 AdobePDFL.dll PDFL 2017/10/31-06:12:59 79.250229 79.250229 AdobePIP.dll Adobe Product Improvement Program 7.4.1.109.46827 AdobeSVGAGM.dll AdobeSVGAGM 79.588619 79.588619 AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924 AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924 AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924 adobe_caps.dll Adobe CAPS 10,0,0,6 AGM.dll AGM 2017/11/22-18:28:12 79.589342 79.589342 ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6 AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279 amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000 ARE.dll ARE 2017/11/22-18:28:12 79.589342 79.589342 AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390 AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390 Bib.dll BIB 2017/11/22-18:28:12 79.589342 79.589342 BIBUtils.dll BIBUtils 2017/11/22-18:28:12 79.589342 79.589342 boost_date_time.dll photoshopdva 11.1.0 boost_filesystem.dll photoshopdva 11.1.0 boost_signals.dll photoshopdva 11.1.0 boost_system.dll photoshopdva 11.1.0 boost_threads.dll photoshopdva 11.1.0 cg.dll NVIDIA Cg Runtime 3.0.00007 cgGL.dll NVIDIA Cg Runtime 3.0.00007 CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1 CoolType.dll CoolType 2017/11/22-18:28:12 79.589342 79.589342 CRClient.dll Adobe Crash Reporter Client DLL 1.6.3.0 dnssd.dll Bonjour 3,0,0,2 dvaaudiodevice.dll photoshopdva 11.1.0 dvacore.dll photoshopdva 11.1.0 dvacrashhandler.dll Adobe Audition CC 2017 10.0.0 dvamarshal.dll photoshopdva 11.1.0 dvamediatypes.dll photoshopdva 11.1.0 dvametadata.dll photoshopdva 11.1.0 dvametadataapi.dll photoshopdva 11.1.0 dvametadataui.dll photoshopdva 11.1.0 dvaplayer.dll photoshopdva 11.1.0 dvatransport.dll photoshopdva 11.1.0 dvaui.dll photoshopdva 11.1.0 dvaunittesting.dll photoshopdva 11.1.0 dynamiclink.dll photoshopdva 11.1.0 ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1150526 81.1150526 icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339 icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339 icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339 igestep30.dll IGES Reader 9.3.0.113 imslib.dll IMSLib DLL 10.0.0.22 JP2KLib.dll JP2KLib 2017/10/31-01:22:04 79.268591 79.268591 libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A) libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0 libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0 LogSession.dll LogSession 7.4.1.109.46827 mediacoreif.dll photoshopdva 11.1.0 MPS.dll MPS 2017/10/31-01:22:04 79.588396 79.588396 pdfsettings.dll Adobe PDFSettings 1.04 Photoshop.dll Adobe Photoshop CC 2018 19.1.1 Plugin.dll Adobe Photoshop CC 2018 19.1.1 PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.5.0 PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.5.0.87 PSArt.dll Adobe Photoshop CC 2018 19.1.1 PSCloud.dll 1.0.0.1 PSViews.dll Adobe Photoshop CC 2018 19.1.1 SCCore.dll ScCore 2017/08/31-12:13:14 81.1150526 81.1150526 SVGRE.dll SVGRE 79.586793 79.586793 svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0 tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118 tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118 TfFontMgr.dll FontMgr 9.3.0.113 TfKernel.dll Kernel 9.3.0.113 TFKGEOM.dll Kernel Geom 9.3.0.113 TFUGEOM.dll Adobe, UGeom© 9.3.0.113 updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1 VulcanControl.dll Vulcan Application Control Library 5.3.0.16 VulcanMessage5.dll Vulcan Message Library 5.3.0.16 WinRTSupport.dll Adobe Photoshop Windows RT Support 19.0.0.0 WRServices.dll WRServices Thu June 21 2017 12:26:24 Build 0.22473 0.22473 wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Accented Edges 19.1.1 - from the file “Filter Gallery.8bf” Adaptive Wide Angle 19.1.1 - from the file “Adaptive Wide Angle.8bf” Angled Strokes 19.1.1 - from the file “Filter Gallery.8bf” Average 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Average.8bf” Bas Relief 19.1.1 - from the file “Filter Gallery.8bf” BMP 19.1.1 - from the file “Standard MultiPlugin.8bf” Camera Raw 10.2 - from the file “Camera Raw.8bi” Camera Raw Filter 10.2 - from the file “Camera Raw.8bi” Chalk && Charcoal 19.1.1 - from the file “Filter Gallery.8bf” Charcoal 19.1.1 - from the file “Filter Gallery.8bf” Chrome 19.1.1 - from the file “Filter Gallery.8bf” Cineon 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Cineon.8bi” Clouds 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Clouds.8bf” Collada 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Color Halftone 19.1.1 - from the file “Standard MultiPlugin.8bf” Colored Pencil 19.1.1 - from the file “Filter Gallery.8bf” CompuServe GIF 19.1.1 - from the file “Standard MultiPlugin.8bf” Conté Crayon 19.1.1 - from the file “Filter Gallery.8bf” Craquelure 19.1.1 - from the file “Filter Gallery.8bf” Crop and Straighten Photos 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “CropPhotosAuto.8li” Crop and Straighten Photos Filter 19.1.1 - from the file “Standard MultiPlugin.8bf” Crosshatch 19.1.1 - from the file “Filter Gallery.8bf” Crystallize 19.1.1 - from the file “Standard MultiPlugin.8bf” Cutout 19.1.1 - from the file “Filter Gallery.8bf” Dark Strokes 19.1.1 - from the file “Filter Gallery.8bf” De-Interlace 19.1.1 - from the file “Standard MultiPlugin.8bf” Dicom 19.1.1 - from the file “Dicom.8bi” Difference Clouds 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Clouds.8bf” Diffuse Glow 19.1.1 - from the file “Filter Gallery.8bf” Displace 19.1.1 - from the file “Standard MultiPlugin.8bf” Dry Brush 19.1.1 - from the file “Filter Gallery.8bf” Eazel Acquire 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “EazelAcquire.8ba” Entropy 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Export Color Lookup Tables 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Export3DLUT.8be” Extrude 19.1.1 - from the file “Standard MultiPlugin.8bf” FastCore Routines 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “FastCore.8bx” Fibers 19.1.1 - from the file “Standard MultiPlugin.8bf” Film Grain 19.1.1 - from the file “Filter Gallery.8bf” Filter Gallery 19.1.1 - from the file “Filter Gallery.8bf” Flash 3D 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Fresco 19.1.1 - from the file “Filter Gallery.8bf” Glass 19.1.1 - from the file “Filter Gallery.8bf” Glowing Edges 19.1.1 - from the file “Filter Gallery.8bf” Google Earth 4 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Grain 19.1.1 - from the file “Filter Gallery.8bf” Graphic Pen 19.1.1 - from the file “Filter Gallery.8bf” Halftone Pattern 19.1.1 - from the file “Filter Gallery.8bf” Halide Bottlenecks 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “HalideBottlenecks.8bx” HDRMergeUI 19.1.1 - from the file “HDRMergeUI.8bf” HSB/HSL 19.1.1 - from the file “Standard MultiPlugin.8bf” IFF Format 19.1.1 - from the file “Standard MultiPlugin.8bf” IGES 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Ink Outlines 19.1.1 - from the file “Filter Gallery.8bf” JPEG 2000 19.1.1 - from the file “JPEG2000.8bi” Kurtosis 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Lens Blur 19.1.1 - from the file “Lens Blur.8bf” Lens Correction 19.1.1 - from the file “Lens Correction.8bf” Lens Flare 19.1.1 - from the file “Standard MultiPlugin.8bf” Liquify 19.1.1 - from the file “Liquify.8bf” Matlab Operation 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “ChannelPort.8bf” Maximum 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Mean 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Measurement Core 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “MeasurementCore.8me” Median 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Mezzotint 19.1.1 - from the file “Standard MultiPlugin.8bf” Minimum 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” MMXCore Routines 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “MMXCore.8bx” Mosaic Tiles 19.1.1 - from the file “Filter Gallery.8bf” Multiprocessor Support 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “MultiProcessor Support.8bx” Neon Glow 19.1.1 - from the file “Filter Gallery.8bf” Note Paper 19.1.1 - from the file “Filter Gallery.8bf” NTSC Colors 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “NTSC Colors.8bf” Ocean Ripple 19.1.1 - from the file “Filter Gallery.8bf” OpenEXR 19.1.1 - from the file “Standard MultiPlugin.8bf” Paint Daubs 19.1.1 - from the file “Filter Gallery.8bf” Palette Knife 19.1.1 - from the file “Filter Gallery.8bf” Patchwork 19.1.1 - from the file “Filter Gallery.8bf” Paths to Illustrator 19.1.1 - from the file “Standard MultiPlugin.8bf” PCX 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “PCX.8bi” Photocopy 19.1.1 - from the file “Filter Gallery.8bf” Photoshop 3D Engine 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Photoshop3DEngine.8bi” Photoshop Touch 19.0 - from the file “PSDX.8bi” Picture Package Filter 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “ChannelPort.8bf” Pinch 19.1.1 - from the file “Standard MultiPlugin.8bf” Pixar 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Pixar.8bi” Plaster 19.1.1 - from the file “Filter Gallery.8bf” Plastic Wrap 19.1.1 - from the file “Filter Gallery.8bf” PLY 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Pointillize 19.1.1 - from the file “Standard MultiPlugin.8bf” Polar Coordinates 19.1.1 - from the file “Standard MultiPlugin.8bf” Portable Bit Map 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “PBM.8bi” Poster Edges 19.1.1 - from the file “Filter Gallery.8bf” PRC 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Radial Blur 19.1.1 - from the file “Standard MultiPlugin.8bf” Radiance 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Radiance.8bi” Range 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Render Color Lookup Grid 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Export3DLUT.8be” Reticulation 19.1.1 - from the file “Filter Gallery.8bf” Ripple 19.1.1 - from the file “Standard MultiPlugin.8bf” Rough Pastels 19.1.1 - from the file “Filter Gallery.8bf” Save for Web 19.1.1 - from the file “Save for Web.8be” ScriptingSupport 19.1.1 - from the file “ScriptingSupport.8li” Shake Reduction 19.1.1 - from the file “Shake Reduction.8bf” Shear 19.1.1 - from the file “Standard MultiPlugin.8bf” Skewness 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Smart Blur 19.1.1 - from the file “Standard MultiPlugin.8bf” Smudge Stick 19.1.1 - from the file “Filter Gallery.8bf” Solarize 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “Solarize.8bf” Spaces 19.1.1 - from the file “Spaces.8li” Spatter 19.1.1 - from the file “Filter Gallery.8bf” Spherize 19.1.1 - from the file “Standard MultiPlugin.8bf” Sponge 19.1.1 - from the file “Filter Gallery.8bf” Sprayed Strokes 19.1.1 - from the file “Filter Gallery.8bf” Stained Glass 19.1.1 - from the file “Filter Gallery.8bf” Stamp 19.1.1 - from the file “Filter Gallery.8bf” Standard Deviation 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” STL 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Sumi-e 19.1.1 - from the file “Filter Gallery.8bf” Summation 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Targa 19.1.1 - from the file “Standard MultiPlugin.8bf” Texturizer 19.1.1 - from the file “Filter Gallery.8bf” Tiles 19.1.1 - from the file “Standard MultiPlugin.8bf” Torn Edges 19.1.1 - from the file “Filter Gallery.8bf” Twirl 19.1.1 - from the file “Standard MultiPlugin.8bf” U3D 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Underpainting 19.1.1 - from the file “Filter Gallery.8bf” Vanishing Point 19.1.1 - from the file “VanishingPoint.8bf” Variance 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “statistics.8ba” Virtual Reality Modeling Language | VRML 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” Water Paper 19.1.1 - from the file “Filter Gallery.8bf” Watercolor 19.1.1 - from the file “Filter Gallery.8bf” Wave 19.1.1 - from the file “Standard MultiPlugin.8bf” Wavefront|OBJ 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “U3D.8bi” WIA Support 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “WIASupport.8li” Wind 19.1.1 - from the file “Standard MultiPlugin.8bf” Wireless Bitmap 19.1.1 (20180206.r.254 2018/02/06: 1156206) - from the file “WBMP.8bi” ZigZag 19.1.1 - from the file “Standard MultiPlugin.8bf”
CUR (Windows Cursor) NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi” Face Control II 2.00 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FaceControl(X64).8bf” Fine Touch 3.25 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FineTouch(X64).8bf” GREYCstoration NO VERSION - from the file “C:\Photoshop64 Plug-Ins\GreycShop_x64_LAA_2013-08-04\Greyc-x64.8bf” ICO Windows Icon/Favicon NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi” Import from FastPictureViewer Codec Pack 3.8.0.96 - from the file “C:\Photoshop64 Plug-Ins\FastPictureViewerCodecPack\FastPictureViewerCodecPack.PhotoshopImport64.8ba” JPEG XR 1, 1, 0, 0 - from the file “C:\Photoshop64 Plug-Ins\Microsoft\JPEGXR_x64.8bi” Lazy Nezumi Pro 18.01.01.0038 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\MouseHookPro64.8li” Luce NO VERSION - from the file “C:\Photoshop64 Plug-Ins\Luce2_64\luce_64.8bf” Reduce Noise v8 8.0.1.0 - from the file “C:\Photoshop64 Plug-Ins\NeatImage8\NeatImage8.8bf” ScriptListener 13.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\ScriptListener.8li” SGI RGB 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) - from the file “C:\Photoshop64 Plug-Ins\SGIRGB\SGIRGB.8BI” StarFilter Pro 3 3.0.5.1 - from the file “C:\Photoshop64 Plug-Ins\ProDigitalSoftware\StarFilterPro3X64.8bf” SuperPNG 2.0 - from the file “C:\Photoshop64 Plug-Ins\SuperPNG\SuperPNG.8bi”
Extensions:
com.adobe.inapp.purchase 2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html” com.adobe.Butler.backend 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html” Libraries 2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html” New Document 2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html” Start 2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html” Adobe Color Themes 6.1.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\KulerPanelHTMLBundle\index.html” SVG Layers 1.0.0 - from the file “C:\Users\jjmac\AppData\Roaming\Adobe\CEP\extensions\SVGLayers\index.html” Export As 3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html” JSX Launcher 0.1.4 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\net.sytes.chuwa.jsxlauncher\index.html” Export As 3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Hi.
Just downloaded the update for CC 2018 and guess what ? Now takes 10 secs to load up rather than 40 + .Still not that speedy but definitely faster.
However, it still takes about a minute to load up an image from the 'edit in' from Lightroom ( admittedly, 30GB files ). Given the spec of my PC, I would have expected a faster load up.....
If the image is one of your Camera RAW file from Lightroom it must go through Adobe Camera Raw Plug-in first so ACR can apply your Lightromm raw conversion adjustments to your cameras raw data and convert it into a RGB Image that opens in Photoshop. So Photoshop needs to initialize then it need to use the Adobe Camer RAW plug-in ACR to open your RAW file. So there is an added path length that must be executed before you will have your Image document in Photoshop. How long it takes to Convert your RAW file mat depend on How many adjustments your made in Lightroom. RAW file are not RGB Images and RAW DATA is not changed in RAW file Adjustment metadata is added one way or an other.
If you really mean 30 gigabytes that's a huge monster of a file and a minute sounds just fine.
There are lots of variables here that you need to break down.
The point is your timings will vary a lot according to which scenario.
Since Lightroom does not support layers I think the only way lightroon could produce a 30GB image file would be stitching image into a stitched panorama dgn file. I do not know for sure for I do not use Lightroom. For IMO Lightroom does not support layers so it really is not compatible with Photoshop therefore I do not use lightroom.
I thought about that, but a 30 GB raw file is orders of magnitude worse than a 30 GB RGB file. That's...big doesn't even begin to describe it. That's Godzilla. How many D800 images - already pretty big - would I have to stitch to get there? We're talking 50 to 100.
That's big, trust me.
Hi Everyone - Duh !!!
I did, of course, mean 30 MEGA bytes ! Sorry for the confusion - it was late.....I do have a few stitched landscapes at about 500Mb and they take a long time to load....unsurprisingly.
Since the last update ( this week ) , Photoshop now loads in about 9 secs - much better and about the same as CC2017. However, when I select, 'Edit in Photoshop CC2018' from Lightroom, it takes over a minute to load up PS and the image. This adds considerable time to my workflow if I need Photoshop. Is this typical ? My RAW files are in 30-50MB range.
