I am writing to you because I would like you to answer a question. I have installed in several computers the 28th version of flash player, and the problem I have encountered in some is an incompatibility with our screensaver. I don't know why some computers fail and others work. Do you know if flash player has any known incompatibility or not with any other program or need some to work properly? Or if it's because of some computer feature? Because I repeat, we have the same screensaver in the company, the same version of flahs player but in some computers works and in others not.
Thank you in advance.
Francisco Erick Briones Garcia
Please upload a copy of the installation logs from a workstation where the upgrade failed to happen and where it succedded. That should be pretty enlightening.
https://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-mac.html
Hi Jerom,
These are the logs. For your information, I installed and uninstalled the version 28, because i have done many proofs with it and currently we have the version 25 which is working now:
In C:\Windows\System32\Macromed\Flash:
=O====== M/28.0.0.161 2018-03-09+18-18-31.878 ========
0000 00000044
0001 00000045
0002
0003 00000010 "C:\Windows\system32\Macromed\Temp\{E26AFB0C-2EF0-4603-A749-89858D8ECE42}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 1
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006
0007 00000013
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_28_0_0_161_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_28_0_0_161_ActiveX.dll
0010 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012 00000012
=X====== M/28.0.0.161 2018-03-09+18-18-33.271 ========
=O====== M/28.0.0.161 2018-03-09+18-27-29.983 ========
0000 00000044
0001 00000045
0002
0003 00000010 "C:\Windows\system32\Macromed\Temp\{C9168CA8-02CD-47B3-95D8-06CB409C1493}\InstallFlashPlayer.exe" -uninstall activex
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
=X====== M/28.0.0.161 2018-03-09+18-27-30.055 ========
In C:\Windows\SysWOW64\Macromed\Flash:
=O====== M/28.0.0.161 2018-03-09+18-18-29.625 ========
0000 00000044
0001 00000045
0002
0003 00000010 "C:\Users\administrador.PEPPERSPA\AppData\Local\Adobe\CC8AC36B-8F45-4E75-80BB-CFDFD3E03D54\C897ED5E-6AEA-4434-AF7B-61952D03E249\8307A5A3-CA22-4EE9-856A-C07BCD75FD68" -install -iv 8 -au 1
0004
0005 00000011 1
0006 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007
0008 00000013
0009 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_28_0_0_161_ActiveX.exe
0010 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_28_0_0_161_ActiveX.dll
0011 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0012 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0013
0014
0015 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0016
0017
0018
0019 00000012
=X====== M/28.0.0.161 2018-03-09+18-19-18.706 ========
=O====== M/28.0.0.161 2018-03-09+18-27-22.840 ========
0000 00000044
0001 00000045
0002
0003 00000010 "C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_28_0_0_161_ActiveX.exe" -maintain activex
0004
0005
0006
0007 00000018
0008
0009
0010 00000018
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034 00000011 1
0035 00000012
=X====== M/28.0.0.161 2018-03-09+18-27-31.705 ========
According to the posted log file, you're uninstalling Flash Player (via Control Panel entry) 8 minutes after it's installed. This isn't going to tell us what the problem is.
<edit>
Do you have full installation log files, that includes previous installations, where the screensavers didn't work? If not, please generate new logs. We would need logs from a system that works and one that doesn't work. Those logs will be too long to post here. Please upload the files to Document Cloud using the instructions at How to share a file using Adobe Document Cloud , or some other file sharing service that doesn't require an account to access. Post the link to the files in your reply.
What kind of screen saver are you using? How is it built?
I attached you the log file.
Archivos compartidos - Acrobat.com
First, was installed the version 26 and our screensaver worked correctly. Now, i upgrade to version 28 and have a bug, because when the moment when the screen saver appears and the moment when the computer is going to lock down coincides, It takes a long time to disappear and in addition, it ends up blocking the computer without the option to avoid it as with version 26.
Aside from re-installing the same version over and over, I'm not seeing any errors in the installation log file.
What takes a long time to disappear? Is there an error? If so, post a screenshot
Does this behaviour only happen with the screensaver? If so, you'll need to provide more information on the screensaver, as previously requested.
What operating system, including version is this happening on?
I cannot attach an image because it is not instantaneous.... If I want to prevent the computer from blocking and the screen saver appears, move the mouse or press any key on the keyboard, but when you do, the computer is "frozen" for about 5 seconds. It does not cause any failure in the computer, but a nuisance that with versions prior to the 27th did not happen to us. We only see what happens with versions 27,28 and now with 29 as well. If before with versions 21-26 it worked correctly and when updating no, it can not be because of the screensaver. What could we do?
I'm not sure I understand what you mean by 'prevent the computer from blocking'. Are you attempting to stop the screensaver from appearing?
Please provide the following previously requested information:
The time set for the computer get blocking and the time set for the screen saver to appear is the same, so when it coincides and you want to prevent the computer from blocking it remains about 5 seconds "frozen". If we don't do that, the screen saver appears and works properly, it's simply at that moment when it fails.
I attach you our screen saver:
Our operating system is Windows 7 32 or 64, in both cases it happens.
What do you mean by blocking?
