Hi guys,
I wonder if you can give me a little push in the right direction with this GREP code.
I want to find words which come before/after a space and a greater than symbol.
(?<=\s>)?\w+(?=\s>)
This is what I have but it doesn't find words which come after the symbol.
Menu > Menu > Menu
Would only find the first 2 Menus.
Thanks everyone
Hi Jakec,
Basically a GREP like
\w([^\r>]+\w)*
would do a very good job (including when the menu item contains inner space), since it captures every string that starts and ends with a word character while not containing any >.
Now, what you want is to make sure that the pattern above is either preceded by >\s, or followed by \s>, in order to exclude lines that do not contain the X > Y > … > Z structure at all. So in fact you have an alternation of two distinct regex, first based on a lookbehind, sec
...Copy link to clipboard
Hi Jakec,
\w([^\r>]+\w)*
Now, what you want is to make sure that the pattern above is either preceded by >\s, or followed by \s>, in order to exclude lines that do not contain the X > Y > … > Z structure at all. So in fact you have an alternation of two distinct regex, first based on a lookbehind, second based on a lookahead:
The lookbehind form is:
(?<=>\s)\w([^\r>]+\w)*
The lookahead form is:
\w([^\r>]+\w)*(?=\s>)
So your final GREP is:
((?<=>\s)\w([^\r>]+\w)*)|(\w([^\r>]+\w)*(?=\s>))
Marc
Hi Marc,
Thanks for your reply, however your GREP seems to miss out the first word in the string.
Menu > Menu > Menu
(?<=\s>\s)?[^\s>]\w+(?=\s>\s)?
This find all of them but because I use the ? it find all other paragraphs too
Do you want to find Soft Menus and Submenus in text, presented as … > … >… > …?
… as:
Hi Obi,
I'm trying to select only the text between the space and > symbols.
I want to make the text bold.
Could you make a screenshot of real texts?
So I want to change text like this to bold (not including the >)
Here, specifically:
\u\l+(?=\h>)|(?<=>\h)\u\l+
> however your GREP seems to miss out the first word in the string (…)
Works for me though, even as GREP-style:
Make sure you have properly encoded the regex. (Keep in mind that backslashes are needed in JS strings for escaping purposes.)
Marc
Hi Marc,
I also tested your GREP with a GREP Style.
No problem with InDesign CC 2017.
Uwe
Hi Marc,
Very sorry, I must have missed something when I copied your code.
It does work That's great thanks for your help.
Marc, I'm writing an article on the use of GREP in InDesign, do you mind if I use this expression as an example?
I'm happy to reference your website or this forum
You're welcome, Jakec. Feel free to share 😉
Marc
And now a short snippet to test my GREP as well:
// FindChange Settings
var FIND_WHAT = "((?<=>\\s)\\w([^\\r>]+\\w)*)|(\\w([^\\r>]+\\w)*(?=\\s>))";
var CHANGE_FONT = "Arial\tBold";
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = FIND_WHAT;
app.changeGrepPreferences.appliedFont = CHANGE_FONT;
// Assuming a TextFrame is selected.
var target = app.selection[0].parentStory.paragraphs.everyItem();
target.changeGrep();
Marc
Hi Marc,
Just for comment!
Doable if first line case, not in the other lines!
I'ld use that code to get this:
Grep code:
\u[\l\d\h-]+(?=\h>)|(?<=>\h)\u[\l\d\h-]+[…~j]?
or
(\u[\l\d\h-]+)(?=\h>)|(?<=>\h)(?1)[…~j]?
Obi,
I made no assumption about what characters are supposed to form a Menu string since it wasn't specified in the original question. My solution is just about splitting a string along a " > " separator, as originally requested. Now of course many refinements could be proposed, depending on what the user actually wants to do, in what context, what Unicode range, and so on.
Marc
Seems to be more complete:
(\u[^\u…~j]+[…~j]?)(?=\h>)|(?<=>\h)(?1)
Works taking in account only one beginning cap.!
Hi, I'm looking for something similar. I need a grep code that will bold text (of the same character style) after the second space. Another way to do it is to bold any text that comes after the Article #.
Article 2 District Standards
Article 3 Building Standards
^Article \d+\K.+
(\K stands for 'match but do not capture, it's a variable-length lookbehind.)
Peter
Thank you so much!!
Follow-up question. How would I adjust the greb to allow for the condition below. Thanks!
Article 3 Building Standards // Section 3.A General Building Standards
If you mean 'Article 3' OR 'Article 3.A' ( where 3.A could be 3.B, 3C, etc)., then try this:
^Article \d\d?(\.[A-Z])?\K.+
that is, Paragraph-initial 'Article'
followed by a space and one or two digits
followed optionally by a dot and a captital
P.
So, this didn't seem to work. The following is what I'm trying to accomplish. The first code from above (^Article \d+\K.+) works on the text prior to the "//". But the other code (^Article \d\d?(\.[A-Z])?\K.+) isn't resulting in no-bold and bold text, as desired. What would be the compound formula for this entire series of text? Thanks so much.
Article 2 Character District Standards // Section 2.A General District Standards
Article 3 Building Standards // Section 3.B Primary Building Types
Knowing you use double spaces before/after "//":
(Article|Section)\h\d+(\.[A-Z])?\h\K[^/\r]+(?=\h\h//|$)
