Is it possible to render selection when it is yellow? I don't have smooth playback, but the timeline is not going to be red.
Make shortcut for: Render in to out.
Select clips.
hit forward slash.
hit shortcut.
The warning bar of yellow is just that ... a warning there might be a problem. Mostly my 'yellow bar' segments play perfectly. If you're have trouble with one, set an in/out, and then in the Sequence settings menu, select "render in to out" ... making sure your preview codec is an intraframe one like Cineform.
Neil
After that the timeline is still yellow and don't play smoothly. If I add renoiser it turns into red. The red timeline I can render and play smoothly, but it is not very convenient.
Select clips.
hit forward slash.
hit shortcut.
What does forward slash do?
Try it.
It didn't help. Render in to out is not working because the timeline is yellow.
How's it playing? The yellow is only a warning that there might be an issue. Most of my sequences are yellow all the time with bits of red showing, and rarely do I need to render for playback.
Neil
It is yellow. And it don't play smooth. Sequence 60 fps.
What is the media on that sequence ... frame-size, format/codec, created by ... camera, screen-capture, phone, drone ... ?
And what effects do you use?
Neil
Exactly. What Ann suggested
Usually, ENTER means you're rendering the red areas in the timeline. To make things easy, I have mapped CTRL+ENTER to render out the In to Out. If you have not set an In or Out point, PPro will automatically render the whole timeline.
Hope this helps.
My mistake: I hitted render selection and nothing happened. Render in to out works!
