I've used layer styles for years, and become quite dependent on them.
Recently with the latest update, when I double-click on a layer's styles to edit them, the window that usually pops up no longer appears. I have to hit "Esc" to return me to Photoshop (which appears locked out, as though the Layer Style window is open, but it's not showing). I've tried every which way I can think of to see this hidden window. If I reset Photoshop's preferences, the Layer Style window will return for about 2-3 uses before the same thing happens again and I can no longer access / see the window at all to further edit my layer styles.
I can't keep resetting my Photoshop prefs every half hour! For one thing, I rely on my prefs being set up a certain way. And that's just too much; this used to function just fine. I guess I could install an older version of Photoshop CC and that might do the trick. But surely there should be a way to get the usual access to the Layer Style window where I can make layer style modifications?
I'm on macOS Sierra 10.12.6 with Photoshop CC 2018 19.1.1
I even uninstalled and reinstalled Photoshop CC 19.1.1 and I'm still having the problem
When the dialog-window is open but invisible does turning on the second monitor make any difference?
What exactly does that do, turning off "use graphics processor" in the performance preferences?
It turns off Photoshop’s GPU-usage – which means certain features like the Rotate View Tool or certain Filter acceleration will become invalid.
Does turning off »Use Graphics Processor« in the Performance Preferences (Photoshop > Preferences > Performance > Graphic Processor Settings) and restarting Photoshop have any bearing on the issue?
It does to seem likely but one can try …
Naturally the issue should not happen on its own but could the dialog have been repositioned to be mostly offscreen?
Is a second monitor involved?
What exactly does that do, turning off "use graphics processor" in the performance preferences? The info panel mentions certain features and interface enhancements, but doesn't mention what those are.
Yes, there is a second monitor involved, but Photoshop (and all my apps) are always on the main monitor (the other one is almost always off). I also use macOS's Spaces feature, which occasionally has caused problems in the past (though not with Photoshop that I can recall). That said, I never move that pop-up panel's location at all, and I'm a careful computer user.
The reason I didn't mention those things above in my post is that they simply seem like red herrings. I'll be using Photoshop just as normal, double-clicking on a layer style to edit it in the pop-up window that has always appeared in the past, and it will work (after the last preference reset) just as it always has, up until, at some random point within the same session (I could just have double-clicked less than a minute ago on the layer style and edited it as usual), so at this point, suddenly clicking again makes Photoshop act as though a pop-up control panel window is open (so you can't use other tools, and I have to hit 'Esc' or 'Return' to exit out)... but there's just no pop-up window there anymore, and won't be until the next preference reset at this point. Isn't that strange? I've used Photoshop for over 20 years, and I don't remember when Layer Styles were introduced, but I've never seen behavior like this in Photoshop before!
You are quite right! It took a few days for the bug to appear again since my last Preference reset, but it just appeared last night.
When I looked, I found the layer styles dialog window hiding on my second monitor, quite unexpectedly. As I mentioned, this is within my usual workflow, so it might have appeared in the appropriate spot seconds before it then leaps out of view onto the second monitor. How strange! This has been an issue only since the latest Photoshop update (19.1.1) I believe (I say I believe because there are times I use Photoshop less in a month, but it is a very recent bug, because I'm a heavy Layer Styles user).
Thanks so much for pointing out what I really should have checked!
