Hi There,
When I open a picture in Photoshop CC 2017 and duplicate it (ctrl+j), the perspective warp tool is not active (gray). Why is that?
De Bruyn Georges
Hi, I found the solution!
My language is Dutch as you noticed on the print screen, so I try to explane it in Englisch.
1: Go to EDIT>Preferenies>Prestations
2: GPU prefeferenties> Use GPU
3: Advanced Preferenties> Mark: Use GPU for faster Calculations.
4: OK
Many Greetings
Good day!
Could you please post a screenshot taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, …) visible?
What are the image’s Color Mode and bit depth?
Pfaffenbichler
Hi, thanks for your reactian!
Picture is in RGB modus and 8 bit
4: OK
Many Greetings
Thank you! This was my problem and solution.
