All of a sudden, I am having quite a few RAW files that have blacks replaced with brown. Asphalt roads are now dirt roads. Any ideas?
Message was edited by: Moderator (to remove whatever that spinning wheel was).
Sounds like you've set your white balance too high.
I think this may be the answer. I’ve never had this issue with my DSLR. However I usually check my settings more often. These funky RAWs were produced by a new drone and the white balance was set way off from where it should have been. After adjustment, I took quite a few test pics and it seems to be all good. Hopefully, this is the issue. Thanks for the answers and suggestions from everyone.
Can you show a screen shot with your develop settings?
Yes it could be a corrupted monitor profile. Try changing it to sRGB to test.
