I have a clip with two separate audio tracks. I apply various audio effects to the 2nd track's clip under "Audio Effects 2" in the Effect Controls panel. I then highlight the relevant effects, right-click, Save Preset..., but no popup appears. If I do the same thing on the 1st track's clip under "Audio Effect 1", the popup does appear and I can save it as a preset.
Anyone else experiencing this? My current workaround is to swap the audio channels so that the clips that need effects are on channel 1 instead of channel 2. But it'd be nice if I could remove that unnecessary step.
Are tracks 2 and higher set up (through patching) to allow new stuff in them? Patching source sequences in Premiere Pro
I'm wondering if the track isn't allowing anything in it, including a preset. Let us know if this helps!
Buck
I haven't done any track targeting or source patching. And I can drag audio effects presets onto track 2. I just can't save from it.
Can you post a screenshot of your complete tracks?
