1
Huion 1060 (8192) Tablet Windows ink Pen Pressure Problem
Mar 07, 2018 Mar 07, 2018
Hello,
I bought 1060 tablet. It is very nice tablet but I have some problems.
-In photoshop when I disable windows ink, pen pressure doesn't work. When I enable windows ink pen pressure works well but some features are laggy. When I use transform tool, it is laggy. I disable press and hold.
I tested last version of photoshop. I try older versions but nothing change.
Tablet Driver version : 13.15.16
But there is no problem on Affinity Photo. It works amazing both enable or disable windows ink.
Regards Serkan,
17.8K
Community Expert , Mar 13, 2018 Mar 13, 2018
Have you all looked at the tablet advice link on this forum's Overview page?
Tablet support for Photoshop on Windows 8
If you are using Windows 10, you can still use the Wintab script the same as with Wacom tablets.  Be careful about the syntax — it needs to be letter perfect, and placed in the right location.
Will you please let us know how you get on?  We get so little feedback from non Wacom tablet users, it leaves us ill equipped to help those users when they visit this forum.
Adobe
Mar 08, 2018 Mar 08, 2018
Hi Serkan,
Sorry that your Huion tablet pen pressure is not working as expected. Could you please take a look at the suggestions mentioned in this discussion Re: Using Huion H610 Pro Tablet Photoshop CC, No Pen Pressure, Please Help!  and let us know if that helps?
Akash
Mar 12, 2018 Mar 12, 2018
hi, im using Huion New 1060PLUS (8192) too and got no problem with my tablet, really working perfectly with photoshop CC 2018.
try reinstall your tablet driver and install the driver from Huion website. hope that help!!!
Hi. My only problem is pen pressure. I try it many times but it didn't work. Pen pressure works well in affinity photo but not in photoshop. By the way when enable windows ink it works. But it is laggy when I use photoshop. I think it is not a hardware problem.
im always enable windows ink on huion driver settings, so i dont know if pen pressure will not work when u turn it off. if hardware problem. im prefer u to upgrade your RAM at least 8GB.
Isn't it laggy when you use crop tool or scrolling ??? I have more than 8gb ram 😃
Trevor.Dennis I created a notepad and now it works.  Amazing =)) No lags or something when I enable windows ink. Everything works great. Thank you so much And thanks to other people who helped me
Apr 05, 2024 Apr 05, 2024
I have followed all steps on this to a T. And tried some things other users have mentioned. I have the latest drivers. It is still not working for me!! And windows ink makes it impossible to do anything right when enabled. I need help.
not laggy at all. idk why that happens to your pc. that bad
Oct 11, 2019 Oct 11, 2019
I have consistently found with my Huion tablet that pressure pens will only work in Illustrator if the tablet was already plugged in and set up when I opened Illustrator. If I forget, I can close the program, then reopen it with the tablet already plugged in.
Mar 06, 2021 Mar 06, 2021
I agree on this, i thought my Hulon tablet was damaged or something but no, I re-opened Adobe Ilustrator (2020) and then the pressure pen worked thank you so much!!!!
Apr 14, 2020 Apr 14, 2020
This is Annoyingly frequent for me. I dont want to reinstall pen drivers whenever I want to draw. Please put another fix
Aug 27, 2020 Aug 27, 2020
To all the HUION users, I got this problem today but solved it with this https://sweetmonia.com/Sweet-Drawing-Blog/wacom-tablet-how-to-disable-windows-ink-keep-pressure-sens...
I know it´s a wacom post, but the solution worked for me. I got laggy features with windows ink enabled, but lost pressure sensitivity when i disabled it.
I created the txt file as the post says, but I named it PSUserConfig instead of PSUserConfig.txt as windows 10 already knows the file format.
I have a Huion 1060 plus (8192) and Im using photoshop CC 2019 on windows 10.
Did not make a difference
