I have subscribed with adobe acrobat DC for 1 year. I want adobe DC open some files automatically and that once I open adobe app Because each time I close my computer I need to search about 7 files in different folders and open each file again. How can i keep some files open auto every time i open Adobe DC?
As mentioned, there's no such option in Acrobat. It is possible to do it using a folder-level script, though.
Another option is this tool I've developed which allows you to easily save and then load sessions: Custom-made Adobe Scripts: Acrobat/Reader -- Save and Load Sessions
Hi Jay,
Sorry for the delay in response.
It is not possible to open the files automatically each time you open the application.
However, instead of looking for files in the different folders, you can simply look the recent list of the Adobe Acrobat DC when you open the application.
It lists the recently open files and you can open them directly from there.
You can also change the number of files shows in the recent list. Launch the application and go to Edit menu > Preferences > Documents.
Then change the number of "Documents in recently used list" and click OK at the bottom to save the settings.
It will be effective after making the changes.
Let us know if you need any further help,
Meenakshi
Or: put a shortcut to each of the 7 files into one folder.
Then you can open the folder and do Ctrl+A, Return. I think it will open them all.
