Hi!
I am working with Indesign 2018 and I have a problem with the index of a book written in Swedish. Swedish has three extra letters Å, Ä and Ö and words beginning with these letters should go at the end of the alphabet / index. However, after generating the index indesign places words that start with Å and Ä immediately after the words starting with A. And the words that start with Ö are placed immediately after the words starting with O. See below.
orsaken och verkan. Se handlingar och effekter; karma
otaliga levande varelser 97, 155
ödmjukhet 134–138
önskande kärlek 80, 183–194
önskeuppfyllande juvel 98, 113, 124, 201, 212
övertygelse 197, 199
P
Palden, Geshe 195
pansarliknande ansträngning 159
potential 5, 52, 99–100, 121, 131, 169–170, 197
för att gynna levande varelser 189, 194, 197
för att återfödas i ett rent land 200
primärt sinne 228. O .
The only way I can fix this at the moment is to manually move the Å, Ä and Ö words to the end after generating the index. But if I need to make change to the index and generate it again then I need to manually move these words again.
I have already set the language to Swedish in the character panel, so I don't know what else to do.
Does anyone have any tips?
Many thanks!
You can use the index panel to change the sorting order for those words.
Hi!
Many thanks for your swift reply. I have applied the changes you suggest and the index now looks like this:
Y
yogan i att jämställa samsara och nirvana 252
yogi/yogini 26, 122, 190. O .
yttra sanningen 195
yttre objekt 10
yttre omständigheter 12, 69, 278
beror på sinnet 145, 179
och lycka 7, 18, 176, 280
Z
åldrandet 32, 60–63, 79
åtaganden 76. O .
för att träna sinnet 150–151
återfödelse 21–27, 46–49, 79
förorenad 47, 53, 56, 71
i ett rent land 200
okontrollerad 34, 66, 147
utan början 56, 207
återfödelse som djur 26, 48–49, 52–53, 76–77
begränsningar 4
återfödelse som människa 47, 52, 55, 119, 175
lidandet 55–69
ägodelar 64, 68, 97, 135, 277–278
ödmjukhet 134–138
So this is much better, since it all the entries are in the right order now. However, there are a couple more changes I would like to make. We don't have any words in the index that begin with Z, so I don't want the Z index section header to be generated.
Also, we are missing the index section headers for Å, Ä and Ö. Any idea how to generate them automatically from the index?
Thanks again!
I will mark this question as answered and start a new thread for my follow up question.
Based on the answer you received for your followup, my answer was not really correct, and was just an unnecessary (for your situation) workaround. (It's a useful tool for me when an entry starts with a number, so I can sort 5th Wheel under Fifth Wheel, for instance.)
True, the second answer I got solved the problem. But thanks anyway for giving it a shot.
Very cool that people want to help out in these forums.
