Hi all,
this is Augusto from Italy.
I am updating a website, deleting all flash animations. Every .swf file is replaced by HTML and Js, while the simpler ones are replaced by myself.
Since I am now about to migrate to a complex animation, I decided to be supported by Animate.
However, when publishing in web, some mistakes occur, that can be viewed in attachments (both via firefox, Chrome or Microsoft Edge).
After re-loading the page, everything looks fine, although the page is already loaded in cache.
I can’t explain this because I did not act anyway in the output generated by Animate. Is it possible that Animate makes mistakes?
Everything can be viewed at:
http://www.parcomonza.org/v4-0/test_animate/autodromo_erosione_parco.html
Is anyone in a position to help me out?
Thanks, regards
i don't see any problems with the link i posted. i tried using 2 computers and 4 browsers.
and the fact you see no problem loading locally is because there's no delay loading your very large bitmaps and audio.
you have a slow (for me) server and an png that takes over a minute for me to load. once that's loaded and cached, everything looks ok.
to remedy add a preloader in your publish settings.
I did it, but it does'nt work
same error
attach a screenshot of your basic publish settings and screenshot of your advanced publish settings.
Here they are the screenshot
is there a forward slash after your images folder?
All Animate Canvas documents use a preloader. The "preloader" in the publish settings isn't a preloader at all. It's actually a throbber--a purely visual effect. I don't know why the Animate team insists on calling it the wrong thing.
I don't understand
in your basic settings, check the paths to images. it looks different than the others.
i don't know it that's causing the problem, but your embedding html is missing things like the definition of lib.
As you can see the paths to images look is equal as the others (see attached images)
The folder "libs" was not created by the publish operation.
I create it manually and I put inside the Js and I modify the HTML code: but nothing change, same mistake!
you don't understand.
resave your project to a new directory and resave it with a new name using the default export directories. retest.
if that didn't correct a problem, post a link to your newly named html
Nothing change as you can see in attached image
copy and paste that link.
I tried to browse the web page not from server but in my pc and it seem go well????
do you see any problem here, autodromo_erosione_parco1
Here what I see
clear your browser's cache and retry.
nothing
must something on your computer or browser causing the problem.
I had tried with Cr Fx Op Fe, all of it has problems??????
Tomorrow i will try with other pc
If I browse the animation from my pc (not from web) everithing goes well, may be becouse the download if image is nearly immediate??
I think so
