I am pleased to announce that we have released InDesign CC version 13.1.0.76 short while ago.
Here are few of the many things we have accomplished this release.
Consistent shortcut key presets
You now have an option to use Photoshop or Illustrator keyboard shortcuts in InDesign.
New presets for mobile in New Document dialog
In this build, new presets for mobile have been added in the New Document dialog. You can
now use mobile presets for iPhone X, iPhone 8, Google Pixel, and more.
Exporting single page PDFs
Now, while exporting an InDesign document as PDF, you have an option to create separate
PDFs for each page or spread.
Merge paragraph borders
You now have an option to merge the paragraph borders of two consecutive paragraphs, if
they have same paragraph border properties.
Endnotes support in InCopy
With this build, endnotes are now available in InCopy as well. You can now import, edit, and
check-in endnotes in InCopy. You can also export endnotes as icma and icml.
Cmd-N preview
While creating a new document, you now have an option to preview the document as you
make changes in the New Document dialog.
Hex input field for colors
Currently, the hex value edit field is available in the Color Picker dialog only. With this build,
the hex value edit field is available in Color panel also.
Cross-reference UI enhancements
When you create a cross-reference, you have to select a paragraph style first and then search
a particular paragraph from a list of paragraphs.
With this build, you can search a particular paragraph from the list of paragraphs with the
help of a search bar.
IDML retains its file name on opening:
In this build, IDML will not open as an untitled document. It will open with the name of the
IDML file.
Full release notes here: March 2018 (13.1) release of InDesign CC Release Notes
Feature Summary: https://helpx.adobe.com/in/indesign/using/whats-new.html
Visit your Adobe Creative Cloud Application and update. If you do not see an update on the application please check for update from the flyout options on the application after clicking on three vertical dots. For step by step process please visit: https://helpx.adobe.com/in/creative-cloud/help/download-install-app.html#Checkforupdates
Srishti
You're calling them "familiar shortcuts." I was plenty familiar with them to begin with. Is there an option to leave them unchanged? How to I reset the preference choice? I'm annoyed by this change.
It is optional to change the shortcuts to Ps or AI.
You can choose to have them as is...
-Aman
Well, my options upon launch were to choose Illustrator or Photoshop shortcuts, I wasn't given an option to leave it unchanged.
Took me a while, but found the preference to change it under Edit > Keyboard Shortcuts.
Fantastic! I can stop using a pdf split utility!
...fifteen years after Insite printers started demanding individual files.
