I processed a batch of images in Raw where I applied a camera/color profile from a color checker passport. I forgot, stupidly, to apply my standard custom preset. After completely working over my images in Photoshop, I realized that they really are a bit off because of this. Is there anyway to make this change, other than completely starting over? Thanks.
In ACR if you Hole the shift key down you will see the open Image button change into an Open Object button. You can also set your ACR Workflow default to open object.
Your Processed files are they layersd files with your RAW files opened as a smart object layer bottom layer?
The bottom layer is just the background; I didn't know the RAW file could be opened as a smart object.
Oh, thanks, JJMack!
Then I can always re-edit it in RAW?
As for now...the only difference in my presets is in the contrast and black levels.
Are the values equivalent in Photoshop, so I could try making tweaks there? Not sure how to interpret "black".
Thank you so much.
