Now that we have 64 bit support with AIR 29 on Windows, is there any way to detect if the application is 64 bit or not during runtime? The Capabilities class does not appear to provide this information.
I will distribute both 32 and 64 bit versions, and would like to show that information to users and send it along in crash reports. Of course, I could change a constant in code between builds, but I'd rather not since that complicates the release process and could easily be missed.
parsing the XML descriptor does not guarantee you that the executable is 32-bit or 64-bit
case where you do a release build from Flash Builder with AIR_WIN_ARCH=64
and the app XML indicate no architecture or a an architecture of 32
to be sure you can load the AIR executable and parse the PE header
to detect the machine type
see here
https://discuss.as3lang.org/t/how-do-you-detect-if-air-is-32-bit-or-64-bit/1221
I have the same question.
Adobe, is there are plans to add new property to Capabilities class to detect 64-bit runtime?
Workaround for now: parse application XML descriptor and find value of "architecture" tag.
see here
Wow, thank you for the in depth post! I will try your solution.
Hopefully this will be added to the Capabilities class though.
Check this topic: 64bit Windows app for native installs?
My code have inside what you need.
No it doesn't
Capabilities.supports64BitProcesses detect if the OS support 64-bit
it is not the same thing as detecting if the current process is 32-bit or 64-bit
Feature request for that: Tracker
