Windows 10, 64 bit
Install fails. Indicates a problem with the Adobe Application Manager. I have tried CCleaner and Cloud Cleaner.
Andrew
Hi Andrew,
Have you tried downloading/installing the latest application manager?
Adobe - Adobe Application Manager : For Windows : Adobe Application Manager
It is the same one for elements and Photoshop CC - I once had a problem when they both tried to do an update.
Are you installing from DVD or download?
Is there any error message?
Brian
I am installing from a DVD. Following your advice I downloaded the Adobe Application Manager. Extracted to a folder on my desktop. Clicked the setup exe. It ran a progress bar indicating that it was updating, but did not show any other dialog boxes. I does not show up in the programs list. I tried to install Elements again, and it quits at 99%. citing the Application Manager having stopped.
The application manager does not show in the application list as you don't directly run it.
The only indication that the application manager has installed is that the dialog box disappears.
Do you have creative Cloud running on your system?
Have you tried the download version?
Download Photoshop Elements | 2018, 15, and 14
Brian
Yes, Please download and install the latest Adobe Application manager, This should resolve your issue.
Vipin
When the installer quits at 99%, do you see any error screen stating that installation failed, or does the installer simply crashes and do nothing?
Vipin
I do not have creative cloud. The error screen says the Adobe Application Manager has stopped working. I uninstalled the previous Elements installation attempt. Ran the Adobe cloud cleaner. Ran CCleaner. Installed new Application Manager, and tried Elements install again with same result.
Sp when you try to install and you see the error message of Adobe Application Manager being crashed, then are you able to launch the product or see a desktop shortcut being created?
If this is the case then it is quite possible that your product Elements was installed successfully, but only have issues with the Adobe Application manager.
Could you see if you are able to see the desktop shortcut for Elements that you are installing?
In case if you dont see the desktop icon being created, could check if you can see PhotoshopEditor.exe on the below location:
C:\ProgramFiles\Adobe\<PhotoshopElements\PreimiereElements>
If yes, please try to launch the product from there and if launched, create a desktop shortcut and see if you are able to the use the product as expected?
Vipin
Nope. No PhotoshopEditor.exe
Can you see PhotoshopElementsEditor on the same location?
Please refer to the below screenshot:
There is no editor... nothing really. Here is a screenshot of the folder. http://prntscr.com/ir5gs0
You would not be able to see the files on the folder navigator in the left panel that is in the screenshot, only the folders are visible from here.
Could you please open the PhotoshopElements15 folder and then search for PhotoshopElementsEditor file and try to launch the app from there.
I tried the whole install procedure again and this time there was an Adobe Photoshop Elements 15.0.exe. When I double click on it nothing happens.
Here is an expanded screenshot... http://prntscr.com/iscq18
I tried installing in Windows Safe Mode and was given this error summary:
Exit Code: 7
Please see specific errors below for troubleshooting. For example, ERROR: DF012 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 1 error(s)
----------- Payload: Elements 15 Organizer(64 bit) 15.0.0.0 {BC3412AF-B3F3-4E4F-910F-814E6C591F23} -----------
ERROR: DF012: Unable to locate file at "C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{BC3412AF-B3F3-4E4F-910F-814E6C591F23}\_1_b723e348d1d2ad036d124253a87a9716"(Seq 2)
Hi Andrew,
What you are pointing to in your screenshot is the Welcome screen.
Try going to the following folder: -
C:\Program Files\Adobe\Photoshop Elements 15
There, look for the following file (the editor) and see if that launches: -
PhotoshopElementsEditor.exe
[note - no spaces if the name]
What anti-virus program do you use?
Brian
I have it installed now. Disabled my firewall and protection. Thanx for the help.
Hi Andrew,
Glad to see you are OK now.
Please tell us which anti-virus/firewall you are using as it may help others in the future.
Brian
