Something is wrong here. Just update my Classic CC to 7.2. I try to stitch pano photos and the Merge Preview generate is extremely low res. This does not happen before. I try 1:1, Smart previews and nothing worked. These photos have been stitched before and I know for a fact that I was getting a higher resolution during Merge Preview.
The problem with the extreme low res display during preview makes it very difficult to set a right projection crop, and warp, especially if any verticals such as trees are bent.
Does anyone have the same problem?
[moved from Adobe Creative Cloud to Lightroom Classic CC — The desktop-focused app]
Define what you mean by "low res". Lightroom doesn't change the resolution of the images. It just combines images to create a panorama, and what ever the pixel content is the result of that combination is what happens.
Hi, I am talking at the stage where Lr displays a window for Panorama Merge Preview and where I choose the projection as well as boundary warp BEFORE clicking on Merge. After merging, the pano photo looks fine.
But only during Preview for merge, the preview looks blurry, everything seems "out of focus" like, nothing is sharp.
Haven't really noticed anything like that. Have you waited a bit to give Lightroom time to catch up?
I waited for over 10 minutes and nothing changed. Try restart LR, everything is up to date, restart desktop. Nothing work. I know this problem just occurred after the update because I try different sets of pano merge (which I used in the past) and they all results in poor quality preview this time, to the point that everything is like out of focus.
I will try it with my labtop and see if anything changes.
Strange.
What is your OS?
How much RAM?
Have you tried disabling your graphics processor?
How much free disk space on your system drive?
You might consider resetting your preferences.
I have latest windows 10 64bit. 8gb Ram. 1tg of disk space left. I will try disable graphics card to see if it changes.
Try my Surface Pro 4 and the pano preview is clear and sharp. So definitely it's my desktop. The only changes in the desktop was updating my LR 2 days ago (haven't used the desktop for couple of weeks).
If disabling the graphics card does make a difference, you might check to see if there is a driver update that you can install that will change things.
Thank you, Jim I will test it out tonight or tomorrow morning and see if it helps.
Hi Jim,
Unfortunately, disabling the graphics card does not work. The preview still looks blurry. Everything is up to date: Lr, graphics card, windows os.
I try uninstall, create a new catalog, nothing work.
I am running out of options and can't pin point to what the cause of it.
Any other suggestions?
Sorry, since I cannot replicate the problem and have never seen that problem reported previously, I don't have a solution. I suppose the only real benefit of having a good preview is to be able to use the warp correction properly. Try reporting on this forum where the developers monitor much more closely and see if they have any solutions.
Thanks Jim,
I will post my question there. in the mean time, the only way to work around this is to view the merge preview in smaller window instead of full screen as before.
Are you running your monitor in its native resolution?
Yes, @ 1080p
