I am looking to only export only certain pages at a time as a PDF, Is this possible and how?
I am wanting to export each Charter as a PDF, as I write the book over a corse of a year.
Thank you,
Jason
I suspect you'll need to save each chapter or group of pages as a new book (see 'Create Saved Book' button at top right corner of Book content window). These can then be exported at pdf as required and joined together in Acrobat (or whatever app you use) as a single pdf.
Thank you Ian for your reply. I will be trying both yours and Woberts to see which will work best.
It is for a project that will be adding a Chapter a month for a year. I am hoping to export each Chapter as it is created in the book for the Group that I am in. After the year I will want to print the book.
Thanks again,
Jason
My approach to this is 'in reverse' to Ian.
I would export the full PDF of the book from Lightroom, then I can use Foxit PDF Reader to "Print to PDF" selected (Chapter) pages.
Thank you Woberts for you reply. I will be trying both yours and Ians as mentioned above to see which will work best.
Thanks again,
Jason
