Elements 15 won't open
Mar 17, 2018 Mar 17, 2018
New install.  No error message. No Lavasoft.  No Web Companion.  Running as administrator, or trying to open in C: programs, PhotoshopElementsEditor.exe responds as "...has stopped working, sending error report... blah-blah-blah { or does nothing at all.... just the spinning timer }
501
Valorous Hero , Mar 18, 2018 Mar 18, 2018
Hi Andrew,
When I did a search on the net for that failing module, it flagged up as part of WinPatrol.
I think that there maybe a conflict between WinPatrol and PSE.
You could see if there is anything on WinPatrol site
You coul try disabling WinPatrol to see if the editor runs then.
I have had problems before and ended up removing the offending software for a week while they sorted it out.
Brian
Valorous Hero ,
Hi Andrew,
You're not having a lot of luck are you
Which version of Windows 10 are you running on - 1709? [Start -> Settings -> System -> About - Windows Specification]
What happens if you click on windows start and select Adobe Photoshop Elements 11 from the application list - do you get the Welcome screen?
Does the organizer load?
Try resetting the editor preferences by deleting the following file: -
C:\Users\[your user name]\AppData\Roaming\Adobe\Photoshop Elements\11.0\Editor\Adobe Photoshop Elements 11 Prefs.psp
Then try loading the editor
Brian
Hello Brian
No I am not having much luck with this. Your solution did not work.  This all started after Windows 10 Pro, Version 1709 updated itself.  If I click on the elements icon, nothing happens except the spinning timer wheel for a few seconds.  I've also tried running as admin and a welcome screen starts up but then crashes.
Valorous Hero ,
Hi Andrew,
I'm running on a fully update version 1709 of Windows and i must be luckier than you.
When you last installed PSE 15, did you do so from DVD or the download?
Do you know how to look at the Windows reliability history? - sometimes that may give a clue
[In the windows search box on the taskbar, enter the word reliability and it should be top of the list]
Is your graphics card driver up to date? - you could try running dxdiag
Brian
Installed from DVD
Valorous Hero ,
Hi Andrew,
Have you got or have had WinPatrol?
Can I suggest you download & run the free version of this malware checker: -
Malwarebytes | Free Cyber Security & Anti-Malware Software
That failing module doesn't appear in my adobe directory.
Brian
Yes, I have the full Ruiware suite: WinPatrol Plus, WinPatrol Firewall and WinPatrol War.  They don't seem to have flagged anything malicious related to this issue.
Valorous Hero ,
Hi Andrew,
Brian
BINGO !!!
I will contact Ruiware
Thank you Brian
