As of yesterday in our Lightroom 4.4 we cannot rename or move any of our photo folders within Lightroom. (I had to do it in the files in Windows Explorer, then link the missing folder in Lightroom). It worked perfectly before that. We can't think of anything different that we have consciously done to change anything. Does anyone know what the problem could be and how to fix it?
That version of Lightroom has been out of production for several years. What has been your procedure for moving folders? What happens when you try to use that procedure now? What version of Windows are you using?
It has been drag and drop to move folders and using the rename drop down to rename files. Now for both a message box says that the named folder cannot be renamed or moved. We have Windows 10, and it worked fine until yesterday.
The first thing I would do is check the permissions on BOTH the original folder and the destination folder (where you are moving the photos to). Both have to have WRITE permission.
Yes, I looked and they both have all the permissions checked.
What is there about your workflow that requires you to move or rename folders?
We don't move files very often, but do rename them every time we download photos as we wish to mention the content items or place locations.
Are those folders open or in use by another process like Windows Explorer or some backup program?
No, the folders are not open. We don't have Windows Explorer open when renaming the Lightroom files.
So what has changed? I don't have Lightroom 4.4 installed anymore. I have Lightroom Classic CC. But if I go to the library and right-click on the folder name I have the option to rename the folder. What happens in your case?
That's when the box pops up with the message that says "The folder (whatever its name is) cannot be renamed or moved."
