I can change the shortcut for "horizontal align left" but not "right"
When I try to make a shortcut to "alt + r" it just pretends I didn't change anything and there is nothing in the "current shortcuts".
I was able to do "alt + l" for left...
Try restoring your InDesign preferences:
Trash, Replace, Reset, or Restore the application Preferences
FWIW. In some earlier versions (must be CS3, or CS5? couldn't recall now) there were problems assigning such kind of shortcuts. A workaround was:
1. Enter Ctrl+Alt+R
2. In a box, select Ctrl+ as text, then from right-click menu select Delete
3. Now you have Alt+R, hit Assign button. Done.
That reproduces here; no way to set Alt+R, directly or via workaround.
Just speculating, but Alt+R does seem to be a near-universally-hardwired shortcut for ®, (the circle-R registered trademark symbol), so it may just be altogether unavailable.
Hi John:
Alt/Opt R does add the ® symbol when the Type tool is active, but ArtSuite2018​ is defining an object-level command. It works as expected on my Mac (Sierra, CC 2018).
~Barb
Before Opt+R on my Mac:
And after:
Thanks, Barb. That's why I suggested that the poster try restoring their preferences. That's one of the things which can be screwed up when preferences "go south."
I agree with you, Steve—I tested it when the question was posted—and would have said the same thing—but you had already taken care of it.
~Barb
Very interesting. It must be the case of OS and ID version. Pity OP didn't specify it.
Or your prefs are corrupted, too?
Here on Win7/CS6 no problem to set shortcut as Alt+ or Ctrl+Alt+ and use workaround (but it's not needed as direct Alt+ works. It didn't in CS3, I think).
BTW, in my customized KB shortcut set I use Alt+R in Default Context exactly as OP wants: for Horizontal Align Right. Many years already.
In Text Mode, yes, Alt+R inserts Registered Trademark Symbol by default. Wouldn't call it 'near-universally-hardwired' shortcut, though. It is specified in a Shortcut Set just like others, and is easily changeable.
