I made a blank composition with images and progression dots. I set it to responsive width/ height but when i make the screen smaller, there's this space that appears and gets bigger as the screen scales down. Help please!
David
The target area is overlapping your triggers. Drag it up to its minimum height and the triggers will move with the target as you reduce the width of the browser.
Hey jeanetted,
Would you mind sharing your .muse file with us so that we can investigate and try fixing it?
For sharing the file you can follow the steps explained here - https://forums.adobe.com/docs/DOC-8652.
Ankush
sure thing! https://adobe.ly/2DLsN3q
So simple! thank you(:
