Hello,
I recently had a client request a couple small website modifications. I hadn't opened the site in Muse for about a year, but I opened the site, made the small changes (just some different text—didn't tamper with any page elements), then published it. Everything was working fine prior to publishing the site, but now it's having some issues with certain objects not pinning to the center of the page at different breakpoints. The website is: http://restorevocrehab.com/
The quotes section towards the bottom is centered fine at larger resolutions, but tablet/mobile resolutions are displaying the quote off to the right a bit (as shown below)
This issue is occurring with some of my CTA buttons, also (as shown below)
I've verified that every object is pinned to the center, but the issue still remains.
Any help would be greatly appreciated!
Joe
Hey Joe,
Can you please try grouping the two boxes and see if that helps?
Ankush
Hey Ankush, thanks for the response—all of the objects are grouped and the issue persists!
Text boxes normally are better done without any pinning but with responsive width. You´ll have to stretch them big enough so they fit into 320 without breaking too much into many lines.
Best Regards,
Uwe
Thanks for the reply! The issue seems to be with the buttons, not the text boxes, though. The quotes section on the bottom is a slideshow that loops through different quotes.
It's just very odd that a year ago when I last worked on this, everything was fine, now with the newer version of Muse, things seemed to break.
You can set the buttons responsive in width as well.
Buttons are kind of text boxes as well, aren`t they?
Best Regards,
Uwe
In a smaller break point, wouldn't pinning to the left work?
It deoends on your design and on the kind of breakpoints you set up.
In fluid width breakpoints, setting the text to responsive width should help.
You may see, that as soon as you set the text to responsive width the pinning disappears.
In fixed width breakpoints no pinning is necessary and helpfull.
Best Regards,
Uwe
