I have two documents open in CS2 (don't laugh, it works OK for me!)
Both are 150 ppi res.
When I drag one into the other, the size is automatically increased by about 2x
Seems to be something else here that I haven't figured, if you can help.
Richard
Hi Richard,
Please let us know which Adobe CS2 application you are using to merge these documents?
Awaiting your response.
You are in Photoshop.
Go to the Image menu > Image size and tell us what the dimensions are for each image in pixels.
Also, what happens when you drag the other direction?
Looks like the pixel dimensions are almost the same for each doc although
one is 10cm wide and the other
is 41cm, so that's what is happening - need to change the pixels on the
smaller one.
Thank you for the tip!
You're welcome!
