Hello
I have a new Dell XPS tower that I bought specifically for editing. I have a strange problem where exported files won't play properly on other computers.
I export to h264/mp4 using vimeo recommendations. It is the same export profile that I have used successfully on a different computer for years.
Though the file will play back without any issue on the same computer it was rendered on when copied to a different computer, parts of the video will play, and parts will not.
What I mean by this is, it may play back fine for 30 seconds then the video freezes but the audio continues to play. After another 30 seconds the video catches up and plays fine again, after another minute this happens again. This pattern repeats itself throughout the entire video. Vimeo is also not able to process these videos, or sometimes it will process but playback on vimeo shows the same problem.
This problem exists on about half of the files I export. The only way I can fix it is to repeat the render until the file is good. This may take 5 renders before I get a good file. AME shows no errors during or after rendering.
It sounds like a codec issue to me but I do not know how to correct this as Premiere should have all the codecs it needs.
I have installed K-lite and VLC, my previous system had that but it did not help the issue on this new computer.
Bad move, codec packs are know to mess up your codecs.
Post screenshot of export settings of the mp4 with left tab to output with an image.
Try vbr 1 pass.
I will try, but can I ask what that would change?
I have used this profile for several years on a different computer without issue.
Something must have changed: windows update?
This is a new computer, I'm not sure it's even had any updates. I'm still using the old computer as well without issue. Both computers have the same OS so they should be getting the same updates.
If you want to upload one of the "bad" files I can take a look at it.
These are 3.5-4GB 45 minute files.
Does the issue not persist in shorter increments? Can you isolate a 20-30 second "problem" area and just export that?
I imported a bad file in Premiere on the old computer (what I have access to right now) and this is what I get
I don't know if there is any point in re-rendering a clip on the newer computer as the video plays back fine on that computer anyway.
Unfortunately I can't do anything with a screenshot. Let me know if you ever upload a problem file.
Sorry I didn't clarify. This is the error I get when I tried to render a sample video to upload.
No solution, but more info that might help:
What are the main particulars of the new PC?
What specific versions numbers on each PC for Windows and PR?
Re Error 99, see this thread for an example:
Also more general troubleshooting these issues:
How to fix issues that cause errors when rendering or exporting
Are you exporting to a local drive?
The timecodes seem odd to me. But one of the troubleshooting suggestions is to look at the timecode reported: 4 hours 34 minutes and change.
Both new and old system is Win 10 version 1709 build 16299.248 and PP 12.0.1 build 69
Yes, exporting to a local drive
Also, if it is of any help, I came up with a temporary solution to get caught up on rendering these videos. I copied the project file and source files to the older system, opened it in PP there and rendered. This file played back successfully.
Use the Match Source - Adaptive High Bitrate preset under the H.264 Format. That'll work everywhere.
I had thought of that, but the only difference between that profile and my profile is CBR vs VBR with a different bitrate. I didn't see that it was relevant. I will try it.
Match Source - Adaptive High Bitrate did not correct the problem.
Another attempt to render in mpeg2 match source also does not work.
Make new project and import old one.
Before exporting reboot machine.
Then there is a problem with that machine, or the player being used on that machine. Don't look to PP to solve that.
I never meant to suggest it was specifically a PP problem. I was only asking for advice on where the problem is and what to do about it.
Do you know what player is being used?
When testing the video on other computers, I use windows media player, VLC player, and import into PP. Vimeo also will not process or playback the video properly.
I just don't use Vimeo, so I can't comment on that. But if VLC won't play the file when using Match Source - Adaptive High Bitrate, then it's very likely that computer has something wrong with it.
Or, it's just old and doesn't have enough juice.
I realize the problem is with the computer. What I was hoping was that someone has run into this before and had some insight as to what was causing this.
It is a brand new custom XPS tower. I spec'd this specifically for premiere. It has enough juice.
Thanks for your help.
