I used the pre-made “Film Lower Third Left Two Line” template on a spot I did last week and it was corrupted when I compressed (using Media Encoder) it for distribution. It corrupted both the mp4 (YouTube setting) and the mpg (Nexus setting) files. It was consistent in its corruption whether I compressed the files together or separately. I compressed multiple times with the same result. Below are screen grabs of the issue. Any solution?
Uncorrupted - screen grab from within Premier
Corrupted - as compressed
Go into Media Encoders Preferences dialog, and uncheck "import sequences natively".
Should fix your ills.
Neil
Neil
Neil,
You rock! This worked, save for one hitch. After I unchecked the "import sequences natively" box I then had to restart Media Encoder. There was no change until I did that.
Thanks bunches.
Neil's answer should be correct, but it's hard to know 100% without actually seeing your steps. But it's probably the same as a problem which was fixed for AME 12.0.1. If so, upgrading to that version (if possible) should also fix it. A third option would be to use direct Export from PrPro since it was only AME that was disregarding the pinned layer on Export.
