Hello. I've been using Adobe products for a couple of years and working with Premiere is a nightmare for me lately. It crashes all the time or gives me all kinds of error messages or image dropouts. I work with RED R3d files. It usually works well about 30 min, then I get "red importer error" or "adobe premiere has crashed". I observed, that some particular effects tend to cause the crash. For example - I apply the Mirror effect on a clip. Then the image goes black and Premiere crashes. When I open the project again and I get to the clip, where the effect is applied, Premiere crashes again. A lot of effects cause black dropout - no image in the program monitor. Nesting clips cause black image as well. I observed, that switching renderer to "software only" helps with almost everything, but it's not a solution because everything is slow as hell and I can't even play a video smoothly. I have Geforce GTX 1050 Ti right now, I used to have Radeon HD 7870 - which is officially supported card and the problems were even worse! I have tried updating the video card, reinstalling, updating Premiere, even reinstalling the whole system...nothing works. I use a lot of programs for photo, video, and music production, playing games occasionally... everything works well and I never get an error message or crash in other programs, so I think my computer is in a quite good shape, but there is something wrong with the Premiere. I like the program, but all the things are really demotivating for me. Please help me. I don't want to learn another editing software. Thank you. Jaroslav
My PC:
Intel(R) Core(TM) i7-3770 CPU @ 3.40Ghz, 4 core
24 GB Ram
Geforce GTX 1050 Ti
Windows 10 professional
Have you tried transcoding your R3D files into an intermediate format? Transcode a few into Cineform and see if you still experience crashing during edit.
No, but I use RED mainly because I Iove the RED workflow. The variability of working with RAW files directly is really important for me. I'll try it, but I'm not sure, this is how I want to work. It should work with R3D. It's supported and it used to work formerly! But thanks for the reply. I'm going to try it at least.
I guess I should mention the reasoning to try this is simply as a troubleshooting measure to narrow down the issue, not as a workflow solution.
Hmm, interesting. I transcoded a few files into Cineform and imported them into the project. It's the same problem. It doesn't crash, but the image goes black when I apply an effect on the converted clip. BUT if I open the file in the new project, then it works. So there is probably something wrong with the project, but I have no idea what it could be.
Does it go black then? If not, check your sequence settings for your R3D timelines/sequences. There may be some settings that aren't matching your footage.
It seems like we are getting to the core of the poodle here. Yes, the "new sequence from clip" works, and yes, resolution of my original sequence doesn't fit the footage. I changed it on purpose, I do it every time because I want to get a 16:9 image out of the RED full sensor format. I didn't know this could be a problem. Now I'm going to change my original sequence to fit the footage and I hope it will help. Thank you!
So, it looked like making sequence the same resolution can help, but no way. It's still bad. The biggest problem for me is, that effects make the image drop out! I apply an effect and suddenly - black screen. Sometimes even changing the size or position makes this. Please help me, I'm desperate.
I have the same card with similar crashing issues and after running through all the customary fixes to no avail I contacted customer support. Evidently this is a problem Adobe and Nvidia are aware of and trying to fix (so we can hope...) and in the meantime all we can do is use horribly slow software render mode...
Try Step 4D below. Report back.
