I had this problem as well sometime after I upgraded to 7.0.3; crashes after about 8-10 minutes after I open a project; for no apparent reason. Wasn't even typing or generating anything; just opened the project.
Tried to fix by remove and reinstall from the CD back to 7.0 (make sure you deactivate the serial number before you uninstall) and it still was crashing so thought it might be a Windows Patch.
Seemed to have fixed the problem when I installed without any of RoboHelp Source control clients or server. no more crashing.. Maybe an adobe tech can respond to this and provide any information on background operations that happen about 8-10 minutes into opening a project like auto-saving something to the Robohelp Source Control product.
One recommendation; use a real source control product like VSS/TFS or Subversion if you are concerned about versioning.
All my updating issues were solved once I upgraded to RH9.
