Internal SSD drive not appearing in LR
Mar 22, 2018 Mar 22, 2018
I have just installed a fresh LR and have a newly installed 1TB SSD for working with some very large photo scans.
My issue is that when importing in LR the new SSD drive is not displaying as a source. This is odd as LR is actually installed on that same drive. My other two internal drives are displaying fine as well as a network drive and two externals. So for some reason I am unable to actually import the photos because LR fails to recognise the drive is there.
The drive works fine in windows explorer, it has a couple of folders of photos and has all the Adobe suite installed to it.
Has anyone run into this odd error before?
1.2K
Community Expert , Mar 22, 2018 Mar 22, 2018
I'm not the OP.  I put up the screen shot so the OP, G S Kelly, could see where the "+" is for adding folders and drives.  It will launch Import where the OP can find the files or folders on his SSD.
Please state your operating system.
Have you tried re-starting the computer?
SSD doesn't really help editing large (or any) photos, other than a trivial amount that you will never notice.
Guide ,
If you haven't imported photos located on that drive, it won't show in the folders panel in the Library module. It should show in the Import module.
Ken Seals - Nikon Z 9, Z 8, 14mm-800mm. Computer Win 11 Pro, I7-8700K, 64GB, RTX3070TI. Travel machine: 2021 MacBook Pro M1 MAX 64GB. All Adobe apps.
Guide ,
Is the "I:" drive the one you are having the issue with?
Why did you put the arrow on the + sign?
Thanks for the help guys. I eventually discovered my stupidity, after I slept on it and went back. The GUI of the importer is just a bit confusing. I needed to use the "select a source" up the top which looks like a heading for the column not a drop down. Still seems odd that it was not listing the drive below with all the others though.
whsprague's method would have also worked as well, so marked correct. Cheers guys.
