Bonjour
Depuis quelques jours, au bout de quelques minutes d'utilisation, je ne peu plus utilisé l'outil déplacement
Il ne se passe rien quand je déplace un calque.
D'un document à l'autre, idem mais j'ai un message d'erreur qui apparait :" Impossible d'utiliser l'outil Déplacement en raison d'une erreur du programme:"
Et Photoshop rame à partir de la. Je suis obligé de quitter/redémarrer plusieurs fois par jour, c'est usant
Tous mes collègues ne rencontrent pas le même soucis
Une idée ? Merci par avance !
Olivier
Hello
In recent days, after a few minutes of use, I can't use the move tool
When I move a layer, nothing happens.
"" From one document to the other, idem but I got an error message that appears: "cannot use the move tool because of a program error:"
And Photoshop oar from the. I am obliged to leave/reboot several times a day, it is exhausting
All my colleagues do not encounter the same worries
Any idea? Thank you in advance!
Olivier
What have you done for trouble-shooting so far?
Restoring Preferences after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved might be a good starting point:
https://helpx.adobe.com/photoshop/kb/basic-trouble-shooting-steps.html
J'ai le même problème depuis 2 jours bien agaçant.
Micheline.
i restart photoshop maybe 5 times a day
it becoming normal and then bug again
Once again: What have you done for trouble-shooting so far?
I provided a Link to a page listing some Photoshop-trouble-shooting routines in post 1.
thank you i'm going to take a look to the list
For answering you, i only restart photoshop when the trouble is coming
Hi
c.pfaffenbichler had given you some links including how to reset Preferences (in post 1). That is different to just restarting Photoshop.
The preferences are saved each time Photoshop closes and can become corrupt if Photoshop closes down unexpectedly, leading to unusual behaviour
So to be specific. Go to Preferences >General and click "Reset Preferences on Quit". Then close and restart Photoshop.
Dave
thanks a lot
i just done what you told me to do
I will let you all know if it s resolving my issue
Bad news it's bugging again
I don't have the issue anymore, just in re starting my computer ^^
Le problème a disparu et je ne sais pas ce que j'ai fait de particulier mais j'en suis bien contente.
Peut-être seulement en redémarrant comme a expliqué Dave.
Bonjour, j'ai redémarré mon PC comme écrit plus haut et le problème a disparu également
ouf je me sens moins seul
i'm feeling lesss lonely
