I'm trying to straighten out a photo of a building; the perspective is a bit off. I wanted to use the Adaptive Wide angle filter, but it is greyed out and not availble. Is there something I can do to turn it on? I have CS6 on an iMac. Thanks, any help is much appreciated.
Is Graphics Acceleration enabled in Preferences > Performance? Adaptive Wide Angle won't work without it.
Have you chosen an Adjustment Layer rather than the image layer?
Check these:
You are working with Smart Object
You are working in CMYK mode
You should use "normal" rasterised layer and RGB mode
Pawel
Thanks guys...got it
