I've installed few LUTs. I want to delete some of them. For example if I have 4 LUTs in the LUTs folder ("LUT 1", "LUT 2", "LUT 3"...) and I color grade with the third one (LUT 3), and then delete "LUT 2" - all the layers that were color graded with the third one is
now being graded with the fourth (because now it's the third one on the list)
what I mean is - that the Premiere remembers which LUT is are using by it's order on the LUTs folder, and not by its name...
How can I delete some of the LUTs without destroying all my work?
For this reason and others, Adobe recommends you do not mess with the program folders or files. Always use the Browse button to add a LUT that does not come pre-installed with the software.
You've gone down the wrong path. My advice would be to backtrack and find the correct path. Don't try to cut through the woods. (Here be bigfeet. )
OK, Tks, I understand, but it's totally not comfortable to browse every time you want to use LUT...
I don't think comfort level is relevant. It's what you need to do.
The solution to your current situation is as previously suggested, redo the work correctly.
