Formatting date
Jan 30, 2009 Jan 30, 2009
Hi
I am trying to set up a Flex application with Coldfusion.
I set up a database table in MS SQL Server, one of the columns is date [datetime]
When I use Coldfusion to retrieve the data through a RemoteObject from using the getAll() functions (generated by CFC Wizard) Flex output the following date format in a datagrid.
Mon May 10 00:00:00 GMT-0700 1976
Can anyone please suggest how I can convert it into dd-mm-yyyy format? I have searched for hours on the internet without success.
Advanced techniques
345
Guest
Jan 31, 2009 Jan 31, 2009
I'm not sure if Flex changes anything but in straight CF you would use:
#DateFormat(dated_on, "dd mmm yyyy hh:mm")#
dated_on is the name of the column in your table that is holding that info.
This from http://livedocs.adobe.com/coldfusion/6.1/htmldocs/functi59.htm
Thanks for your suggestion. I found an easier fix in Flex.
consider posting the fix you found here, please, so someone else may
benefit from it - that's what these forums are about, after all...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Documentation
