I have been using my touchscreen laptop with my bamboo ink stylus. It was working properly until a day ago. Now I every time I want to use the pen, I need to wait for a second to do a brush stroke or eraser tool. If i use it normally, it will recognize it as a finger and scroll in the direction of the stroke. This cause slow drawing time than I normally get. ANyone know how to fix this?
Other Wacom users are also having panning problems Every tool acts like Move Tool, and latency: Intuos Pro
The thing is I cam not using a wacom pad or tablet. Im drawing straight on my touch screen laptop
Photoshop supports touch jesters like scrolling, zooming etc. Not touch drawing for tolls like paint brushes you need pen support not a stylus they are a finger substitute lack lack some pen functions like position the cursor before touching the surface.
The latest version also has a smoothing function for pens and brushes. There is a percentage of smoothing on the adjustment banner at the top of the screen. It does slow down the drawing speed, but it creates smoother results. You can turn it on and off as needed.
I am using this. Before the problem, this pen(stylus) worked perfectly on Photoshop CC 2017/2018. When I create a stroke. It takes a second before photoshop recognizes the pen's tip (nib). It acts as if it was the move command, scrolling in the direction of the pen's movement. The brush smoothness is fine. there is no delay there. the delay happens at the start of each stroke.
Last night after messing around, I noticed that I had to press the lower button on the pen to bypass the problem. But i dont want to have to press the button consistently to create a brush stroke or easer. Since this didn't happen before, it's got me thinking that Photoshop itself changed a setting. The Pen's driver is updated to its recent driver for my laptop and the settings are at the default as before.
The bamboo INK is at Wacom Pen for devices like Microsoft Surface Pro machine that support pen via Microsoft ink. If it worked before it should still work if Photoshop is using INK API for Pen support. You should not add a PS user Config file to Photoshop use Wintab API and not use INK Api. Your Bamboo pen only supports INK API. If your Bamboo a Device driver from Wacom to work you need to install it. Your Bamboo INK is a Pen device the require your machine have Pen support it is not a stylus that uses touch support. If pens support is not operational you fingers using the Bamboo may activated touch ]]support. When a pen in near your display if Pen support is working it should disable touch support and interface with Photoshop. Your Laptop must have hardware the supports pen devices like the Wacom Bamboo and pens like Surface ntrig pens. If is does not a pen will do you no good. You stated the Bamboo worked in the past if it did and support pressure your machine has both touch support and pen support. Like Surface Pro machines.
What model laptop do you have?
I did not add PSUserConfig. I have an Asus Q534UX
I do not think your Asus has what is required to use your Banboo. Please read this link
https://www.windowscentral.com/best-laptops-pen-support-windows-ink
ASUS VivoBook Flip 12 TP203NA | 2-in-1 PCs | ASUS USA
ASUS ZenBook Flip S UX370UA | Laptops | ASUS USA
ASUS ZenBook Flip S UX370UA | 2-in-1 PCs | ASUS USA
I've been using my bamboo for several months with various applications without a problem until several days ago. It works properly in Illustrator, Rhino, and other CAD programs.
System also says its Pen and Touch enabled. Is there way to figure out how to update systems pen support driver?
Windows show you have Pen support. Is Photoshop Seeing you have a pen. With a document open a brush tool active does Photoshop see you have a pen or show a yellow warning in Brush Setting Shape Dynamics?
