Hey guys,
i have this weird problem with photoshop since i have come back from my hollidays. If i try to draw smth while my canvas is zoomed out and completely visible everything is working normal. However as soon as i zoom in it only draws when i drag my pencil from left to right or the other way around. If i try to draw in any other direction it just moves my canvas. This happens with every tool i use when zoomed in, no matter if i select the zoom tool again or the eraser. If i turn off windows ink it works perfectly normal, but i dont have any pressure sensitivity at all anymore. Ive tried so many hot fixes already, and im getting really frustrated. I reinstalled Photoshop, the wacom driver and the graphic cards driver already. Does someone know a solution that might work?
Try uninstalling this Windows update
If turning off Windows Ink fixes the issue, take a look at Trevor's reply in this thread to see if it fixes the pen pressure issue
Use Windows Ink Issue with photshop CC 2015.
This bit
1. Create a file that contains instructions to revert to the WinTab functionality.
2. Create a text file in a text editor such as Notepad.
Type in the following lines:
# Use WinTab
UseSystemStylus 0
3. Save the file as a plain text file named PSUserConfig.txt
4. Put (copy) the file into the Photoshop settings folder: C:\Users\[User Name]\AppData\Roaming\Adobe\Adobe Photoshop CC 20XX\Adobe Photoshop CC 20XX Settings\
5. Restart Photoshop and check the pen pressure and overall performance.
Ye, ive tried that one, but it didnt work. I opened the notepad, typed in:
# Use WinTab
UseSystemStylus 0
, saved it under the given file name, and dropped it in the photoshop 2018 settings. But it had no affect.
Did you save the file with a .txt extension
People are reporting an issue similar to what you are experiencing, take a look at these threads
EVERY TOOL IS ACTING AS THE MOVE TOOL
Unwanted behavior with pen after using some functionalities
Seems to be related to a recent Windows update
ok, uninstalling the last windows update u marked above actually worked, i hope this will be permanent. Thanks so much, ive tried fixing this for the last 3 days.
oh and for all ppl who have the same problem and tried to change the pen and touch options, which i tried aswell, but couldnt find them because they simply didnt exist anymore: Since i uninstalled that last windows update they reappeared again.
It will until Windows update decides to install the update again LOL
i deactivated the windows updater permanently for now, i guess i will have to check once in a while wether they have fixed that issue with another update, because i dont wanna miss out on any security relevant updates over a longer time period
I had this same problem. I was searching ways to uninstall the update when I found that Microsoft sent out a fix.
Heres the link to the site
Just scroll down until you find the "Known issues in this update" and you'll see the picture I just posted.
Hope this helped.
