Ok , this is driving me crazy , please help
Premiere Pro cc2018
mxf files located on external drive (exFAT)
files are from different 4k cameras (downgraded)
(the mxf files were created using davinci software , for each original file there are three files created , one with image and sound and two containing sound only -if this is relevant at all )
when importing from external disk files would take ages to import (on an imac)
after I moved them in the external drive files would import (almost) fine .
so after I moved the project to another pc there was this particular folder who wouldn't link no matter what (reported generic error)
I copied the folder to another external drive and the files would link fine .
but after I moved the files to another location and tried to re-link them I would get the same error .
I copied the files again to another drive and the problem was solved .
I tried to trash the preferences etc but that doesn't seem to solve the generic error problem .
Any suggestions ?
I'm on the edge of a mini nervous breakdown , cc2018 has been giving me all sorts of crazy problems
My first recommendation is Step 3H below.
Thank you Jim_Simon ,
the project is too big to move all of the files in internal drives but it seems this is what I'll do ,
hope it works
Hard drives have gotten pretty big, larger than externals.
4TB and higher, Desktop Internal Hard Drives, Hard Drives, Components - Newegg.com
according to me PP2018 and still malfunctioning, I prefer to use still premiere cs6 even with the 4k, much faster and more reliable.
good luck anyway
