I have a Cross Dissolve at the end of a clip and one at the end of the previous clip but only one is working.
I tried several transitions at this location and none of them seem to be working. I have transitions between other clips in this sequence and they are working, so what's going here?
One of the first things to check with cross-dissolve issues is do you have the necessary 'handles' on the clip ends at that editing point?
A 'handle' is extra frames either past or before the edit point ... for the clip in front, that would be extra frames past the cut; for the clip behind the cut, extra frames in front of the cut.
If you don't have handles, there's nothing to dissolve ...
Neil
Neil
Oh, that makes sense! What I did was cut the clip and add a transition.
The cross dissolve is working alright but you are not seeing anything as its using the same frames (handles) as the clip.
There is no point in adding a transition on a straight cut and doing nothing with that cut.
Turn on Show Through Edits under the wrench in the timeline.
Thanks for the great suggestion, Ann!
Ann's comment about turning on Show Through Edits ... is a real brain-saver on working with transitions. Highly recommended!
Neil
