Hello,
I'm working on some script stuff which selects random colors by input, but there some problem with photoshop to select some colors. Just giving RGB Values through script & it's not making a selection.
Works with most of random colors, but not all. please please gimme some solution.
Here are RGB values which photoshop not selecting.
1. R:4, G:99, B:138
2. R:109, G:225, B:147
Here is the script:
var chercheCouleur = new SolidColor();
chercheCouleur.rgb.red=109;
chercheCouleur.rgb.green=225;
chercheCouleur.rgb.blue=147;
selectColorRange(chercheCouleur);
function selectColorRange(scObj)
var desc = new ActionDescriptor();
desc.putInteger( charIDToTypeID( "Fzns" ), 0 );
var cDesc = new ActionDescriptor();
cDesc.putDouble( charIDToTypeID( "Rd " ), scObj.rgb.red);
cDesc.putDouble( charIDToTypeID( "Grn " ), scObj.rgb.green);
cDesc.putDouble( charIDToTypeID( "Bl " ), scObj.rgb.blue );
desc.putObject( charIDToTypeID( "Mnm " ), charIDToTypeID( "RGBC" ), cDesc );
desc.putObject( charIDToTypeID( "Mxm " ), charIDToTypeID( "RGBC" ), cDesc );
executeAction( charIDToTypeID( "ClrR" ), desc, DialogModes.NO );
Thanks in advance.
In general, it seems that ColorRange processes all your colors in Lab mode, regardless of what mode it was given input colors.
He still converts them to Lab. And it does it on the same algorithm as Eyedropper.
This algorithm (the conversion of RGB to Lab) is different from what happens when executing such code.
...var c0 = new SolidColor();
c0.model = ColorModel.LAB;
c0.rgb.red=109;
c0.rgb.green=225;
c0.rgb.blue=147;
var c1 = new SolidColor();
c1.model = ColorModel.RGB;
c1.rgb.red=109;
c1.rgb.green=225;
c1
This is a bug of Photoshop СС
Read this topic sampled colors in color range is not recorded by scripts
Thanks for reply,
I'm not talking about Photoshop СС. I'm using Photoshop CS6 13.0 x64. And it is working on most of the colors. Please go through again & check if there can be any solution for it.
Thank You
Excuse me, but now there is no time. It's also like a bug. I'll try to figure it out later.
c0.rgb.red=109;
c0.rgb.green=225;
c0.rgb.blue=147;
c1.rgb.red=109;
c1.rgb.green=225;
c1.rgb.blue=147;
alert(c0.lab.l.toFixed(4) + " " + c0.lab.a.toFixed(4) + " " + c0.lab.b.toFixed(4)+ "\n" +
c1.lab.l.toFixed(4) + " " + c1.lab.a.toFixed(4) + " " + c1.lab.b.toFixed(4))
In addition, it depends on the file's profile and bit depth.
In Lab mode 16 bit, ColorRange with Fzns = 0 does not work at all adequately
For your case, you can upgrade the code like this. At least on your two colors works in RGB8 or RGB16 mode with different profiles.
chercheCouleur.model = ColorModel.LAB;
//chercheCouleur.rgb.red=4;
//chercheCouleur.rgb.green=99;
//chercheCouleur.rgb.blue=138;
cDesc.putDouble( charIDToTypeID( "Lmnc" ), scObj.lab.l );
cDesc.putDouble( charIDToTypeID( "A " ), scObj.lab.a );
cDesc.putDouble( charIDToTypeID( "B " ), scObj.lab.b );
desc.putObject( charIDToTypeID( "Mnm " ), charIDToTypeID( "LbCl" ), cDesc );
desc.putInteger( stringIDToTypeID( "colorModel" ), 0 );
Thanks for the Valuable answer.
this worked better than my code, but it is still not selecting some range of colors
try this one :
red=60
green=105
blue=210
Thanks.
try this one :
red=60
green=105
blue=210
Works fine. CS6 13.0.1.1 x64 win7
RGB8 (srgb, adobergb, working srgb)
