I recently upgraded to LR Classic CC on my (new) Window 10 computer. I cannot for the life of me print borderless as I did on the same printer in previous version of LR. All page and printer settings are set, printer comes to life but nothing prints. If I export to a jpg, prints fine but with borders. Anyone have a clue and or procedure for printing borderless directly from LR. Thanks, Dan
Just as a checkpoint, are you selecting borderless in the page setup, which allows you to set options in the printer driver? Does the image display as borderless in the Lightroom print module? What printer are you using?
Thanks Jim for quick response. I am selecting borderless in "Page Setup", image displays as borderless once I go to Layout and drag margins over to zero and make cell size in this case 4x6. Printer is an HP Photosmart Pro B8350.
Still no luck.
Still no luck, any other suggestions?
Have you done Step 9 from the User Manual? http://h10032.www1.hp.com/ctg/Manual/c00756121
9. Select the 'Scale to paper size' check box to automatically resize the image to print without a border.
I may have a solution - was having the same issue until I figured it out.
I tried selecting Border > None in print menu but the problem persisted, until I did the following.
In print module click Page Setup on the bottom left and make sure whichever paper size you plan to print with has the borderless version selected. After I updated, my 8.5x11 prints were locked on US Letter, not US Letter Borderless. Problem went away after changing paper type.
