We can get uniform pixels of one size by using Filter > Mosaic > Pixelate in photoshop.
But how to get pixels of varying sizes as in the varyingpixels image( the image shows 10*10,9*10,8*10,7*10 size pixels and not perfect squares but I wish to achieve perfect squares 10*10,9*9,8*8,7*7,6*6..) with a series of
10 size pixel
9
8
7
6
5
4
3
2
1
2
3….
And repeat in reverse. I want to achieve the varying size pixels without losing the image.
This is possible with sizes who are multiples of each other. For eg:
6
3
3
6
And so on…
But with non-multiples there is an overlapping issue vertically . The horizontal difference of pixels is sorted with getting the same image in different sizes pixels separately. And then bringing them together row by row? But the main issue comes with overlapping vertically as seen in the below image.overlapping image.
How to resolve that?
So my question is how to get varying size of pixels in one image without losing the image.
Pixels in an image have no Physical size. On displays they are the displays pixels sized and in prints the Print Resolution DPI is the size the image's pixel print size. They are all printed the same size and do not overlap. Mosaic tiles are create with pixels there is no one to one relation between pixel and image tile.
The mosaic filter starts at the top of the image each time, even if you give it a selection strip to work , so will not produce the square tiles in the exact way you want.
The Photoshop scripting forum may be the best place to ask for help with this task. I have moved your post over to that forum.
Dave
Thanks dave .Yes I actually meant the mosaic tiles and not the pixels. Can the effect be achieved by changing the image with offset.
