Does anyone have, or know if it's possible to remove hidden/unused layer effects of selected layer(s) with a script? (Not on every layer in the document, only selected layers)
For example here I'd have to drag each unused effect to the trash can at the bottom
Would be great if you could remove the hidden ones while still leaving those that are visible via a script
This can be due to layer protection. Try this variant.
...var r = new ActionReference();
r.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID("targetLayers"));
r.putEnumerated(charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
if (executeActionGet(r).hasKey(stringIDToTypeID("targetLayers")))
var list = executeActionGet(r).getList(stringIDToTypeID("targetLayers"));
var offset = 0;
try { activeDocument.backgroundLayer } catch (e) { offset = 1;
Check my scripts: Magic scripts for Photoshop
I have one for layer effects and one for smart filters. But it is for all layers in document. If you want skip some layers, you can lock them.
Thanks, I saw that
But really, I'm looking for a script that runs on the selected layers.
You or somebody else could change my code. But I will not do it.
Not really the kind of answer I was looking for on a 'help forum', haha.
But thanks, I might try that.
Very useful scripts, thank you, bro!
Try
var offset = 0;
try { activeDocument.backgroundLayer } catch (e) { offset = 1; }
for (var n = 0; n < list.count; n++)
var idx = list.getReference(n).getIndex();
r.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID("layerEffects"));
r.putIndex(charIDToTypeID("Lyr "), idx+offset);
if (!executeActionGet(r).hasKey(stringIDToTypeID("layerEffects"))) continue;
var d = executeActionGet(r).getObjectValue(stringIDToTypeID("layerEffects"));
for (var i = 0; i < d.count; i++)
var key = d.getKey(i);
var type = d.getType(key);
if (type == DescValueType.OBJECTTYPE)
var enabled = d.getObjectValue(key).getBoolean(stringIDToTypeID("enabled"));
if (!enabled)
var d2 = new ActionDescriptor();
r.putClass(d.getClass(key));
r.putIndex(charIDToTypeID("Lyr "), idx + offset);
d2.putReference(stringIDToTypeID("null"), r);
executeAction(stringIDToTypeID("disableSingleFX"), d2, DialogModes.NO);
else
alert("no selected layers")
Thanks! I've tried it, but get the following error message:
- The command "Delete Layer Style" is not currently available.
Line: 40
executeAction(stringIDToTypeID("disableSinfleFX"),d2,DialogModes.NO);
Any idea how to fix that?
var offset = 0;
var unlock_flag = false;
var lock = false;
var del_cnt = 0;
r.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID("layerLocking"));
if (!unlock_flag) lock = executeActionGet(r).getObjectValue(stringIDToTypeID("layerLocking")).getBoolean(stringIDToTypeID("protectAll"));
if (!enabled)
if (lock && !unlock_flag)
var d1 = new ActionDescriptor();
var d3 = new ActionDescriptor();
d1.putReference( charIDToTypeID( "null" ), r );
d3.putBoolean( stringIDToTypeID( "protectAll" ), false);
d2.putObject( stringIDToTypeID( "layerLocking" ), stringIDToTypeID( "layerLocking" ), d3 );
d1.putObject( charIDToTypeID( "T " ), charIDToTypeID( "Lyr " ), d2 );
executeAction( charIDToTypeID( "setd" ), d1, DialogModes.NO );
unlock_flag = true;
++del_cnt;
alert(del_cnt + " LayerEffects have been removed");
else
Perfect, thanks a lot!
we made a Photoshop plug-in that can do this. The unlimited version is 12$.
Full Version (12$):
https://exchange.adobe.com/apps/cc/c36e02fb/swift
Trial Version (Limited to 5 Actions):
https://exchange.adobe.com/apps/cc/412c1dcd/swift-trial-version
Its also a big help with getting the layers selected.
