7 Replies Latest reply on Apr 6, 2018 1:18 PM by Jörg Hoh
    Apache 2.2 SSL Proxy for AEM 6.3.1.2 Author -- Can't Login
    thisthatheotter Level 1
      I have an AEM 6.3.1.2 author instance configured to authenticate either locally or with LDAP. Both authentication methods work on my local machine via localhost:4502, and when moved to the Apache host and accessed with its port number :4502 -- hostname:4502, when I access it on the Apache host via the SSL proxy, I can't login with either local (admin account) or LDAP authentication.
      I tried adding hostname to the referrer filter configMgr setting as well as selecting "allow empty" -- neither affected the behavior.
      Login page loads with SSL but login fails.
      load login page -
      30.03.2018 09:26:36.190 *INFO* [qtp1289250881-9193] org.apache.sling.auth.core.impl.SlingAuthenticator getAnonymousResolver: Anonymous access not allowed by configuration - requesting credentials
      30.03.2018 09:26:36.426 *WARN* [5.6.7.8 [1522416396423] GET /libs/granite/core/content/login.html HTTP/1.1] libs.granite.core.components.login.login$jsp j_reason param value 'unknown' cannot be mapped to a valid reason message: ignoring
      30.03.2018 09:26:37.142 *INFO* [qtp1289250881-9195] org.apache.sling.auth.core.impl.SlingAuthenticator getAnonymousResolver: Anonymous access not allowed by configuration - requesting credentials
      try to login -
      30.03.2018 09:26:51.623 *INFO* [qtp1289250881-9193] org.apache.sling.auth.core.impl.SlingAuthenticator getAnonymousResolver: Anonymous access not allowed by configuration - requesting credentials
      30.03.2018 09:26:51.992 *INFO* [qtp1289250881-3471] org.apache.sling.auth.core.impl.SlingAuthenticator getAnonymousResolver: Anonymous access not allowed by configuration - requesting credentials
      My VirtualHost looks like this (in main httpd.conf)
      NameVirtualHost 1.2.3.4:443
      <VirtualHost 1.2.3.4:443>
      ServerName hostname
      RewriteEngine On
      SSLProxyEngine On
      RewriteCond %{HTTPS} off
      RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
      ProxyPass / http://hostname:4502/
      ProxyPassReverse / hostname:4502/
      SSLEngine on
      SSLCertificateFile /etc/pki/tls/certs/xyz.crt
      SSLCertificateKeyFile /etc/pki/tls/private/xyz.key
      SSLCertificateChainFile /etc/pki/tls/certs/xyz.crt
      </VirtualHost>
      The response headers look more or less the same when I access via port and it works vs. via the SSL proxy and it does not work ... except in the proxied connection I see a few redirects to SSL, I also see a 302 for /libs/granite/csrf/token.json to http://hostname/libs/granite/core/content/login.html?resource=%2Flibs%2Fgranite%2Fcsrf%2Ft oken.json&$$login$$=%24%24login%24%24&j_reason=unknown&j_reason_code=unknown ... no https not sure if that's a clue ...
      Thanks for any info on what the log means and how I might resolve.
