Button doesn't stop audio/playhead, even with "Continue Playing the Project" unchecked
Mar 13, 2018 Mar 13, 2018
I have a button on several projects that is set to Open a URL in a new window. Ideally, when someone clicks on the button, I want the presentation to pause (slide advancement and audio) until they return and press the play button. The "Continue Playing the Project" button is unchecked, but the project continues playing. Is there something else I should be doing in addition to unchecking "Continue Playing the Project"?
Screen Shot 2018-03-13 at 9.10.29 AM.png  Screen Shot 2018-03-13 at 9.10.53 AM.png  Screen Shot 2018-03-13 at 9.11.07 AM.png  Screen Shot 2018-03-13 at 9.11.20 AM.png
Here are the settings for the button. I'm using Captivate 2017 and previewing/publishing HTML5.
1.2K
Explorer , Mar 14, 2018 Mar 14, 2018
Hello,
I am not sure if you are still having this issue, but if so I would suggest setting up an advanced action to solve this problem. I solved a similar problem like this before by converting my link into a button and creating its own action which had the following:
  • Pause
  • Open URL or File (In New Window)
  • Hide Pause Button
  • Show Play Button
For my play button, it would have a simple continue action attached. In practice, it's always picked right back up for me from where it was paused at.
If you talk about Slide audio, it will not be stopped until you check 'Stop Slide Audio' under the Options Tab of the button.
Thanks, Lilybiri! I've experimented with the "Stop Slide Audio" box before. It does stop the slide audio, but when I return and press play, there is silence for the remainder of the slide. Once it advances to the next slide, audio plays again. Historically (when we were using Flash), we've had the button show for the entirety of the slide, since the audio picked back up where it was paused. Perhaps the solution is to not have the button display until the audio we want people to listen to is over.
Sorry, it is not necessary to stop slide audio in this case, just double-checked for HTML output. Everything works for me as expected, so I'm wondering what is going awry for you. Since the length of the audio defines the length of the slide, and both Playhead and audio are stopped when you uncheck the option 'Continue Playing Project' while opening an URL in a New window, you shouldn't have troubles with that setup.  Can you try to insert a text container with the var 'cpInfoCurrentFrame' to check? I didin't publish my example, just Previewed HTML in Browser (F11).
I added a text container with the var 'cpInfoCurrentFrame'. When I previewed in the browser, the number (Does this represent the playhead? I haven't done this before) stopped but the audio continued to play. In fact, the audio continued on to the next slide, but the slide did not advance.
If I repeat this "Stop Slide Audio [When Clicked]" selected, the audio stops and the number in the text container stops. When I click play to resume, just the number resumes. The audio doesn't return until we move forward to the next slide.
Strange, I really double-checked myself and I didn't have to pause the slide audio, it was paused automatically when I unchecked the option to Continue Playing Project, and opening URL in a new window.
That variales shows the frame number, I use it all the time when trying to get the Timeline doing what I want. You can have a look at some of my blog posts about TImeline, and maybe this interactive movies:
Captivate'sTimeline
PauseTypes
I hope you are talking about slide audio, and that you take care to leave a small gap before and after the audio timeline:
Thanks for your help, Lilybiri! It's helpful to know that unchecking "continue playing the project" should be working as I expected, so I'll keep exploring.
(And yes, I was talking about slide audio. I haven't been leaving spaces at the beginning and end. I added the spaces in, but it doesn't seem to have affected this case.)
Hello,
  • Pause
  • Hide Pause Button
  • Show Play Button
Mar 15, 2018 Mar 15, 2018
Mar 30, 2018 Mar 30, 2018
We can use advanced actions to pause the slide along with the audio here. This will work for SWF and HTML outputs.
We can assign value 1 to the variable cmCmndPause through advanced action. It will pause the slide along with the audio. Here is how this will look.
The play button on the playbar can be used to resume the project. This will resume the audio and the slide from where we have paused it.
Just a tip: since a couple of versions (8?° you don't need to toggle the cpCmndPause anymore. There is a Pause command and a Continue command.
Hi victoriak23188594, Debiprasad, and Lilybiri! Thanks for your help. I worked with Adobe this morning, and they confirmed that Advanced Actions (cpCmndPause/Pause, with an optional second button for play as Victoria suggested) is the best way to create the effect I was trying to create, as unchecking Continue Playing the Project doesn't work with HTML5 lectures. I'm adjusting our practices now. I appreciate all your ideas!
It is up to you but I always use Toggle buttons, much more user friendly. If you really want to stick with the old command that toggles the cpCmndPause, you have to remember that to resume you have to use cpCmndResume. That is the reason I mentioned that it is much better to use the state of the art commands 'Pause' and 'Continue' instead of that very old workflow.  Since Mutlistate objects appeared I never use two images anymore, but states to show the present status of Play or Pause. Watch thism ovie:
PauseTypes
You'll see such a multistate button for Play/Pause and also have the experience that not all audio can be paused.
Help resources
