Looking for help or the shortcut for the following. I have a bunch of clip sin my sequence. then i decide in the middle that sequence, i want to move several of the clips right to add some things like titles and photos. how can i move the clips and everything beyond it to the right ?
The Track Select Forward Tool will probably do what you're looking for.
You could also do a Marquee Selection around the clips that you want to move with the Selection Tool and then click and drag or press plus ("+") on the extended keypad and enter a time amount for the selected clips to be moved.
Hold down ctrl while adding/inserting the clip.
Or for a particular track: ctlr+alt.
thank you for your help
