I recently am in the process of making a logo so I used a wolf from a stock image website. However, the wolf's tail end is cut off. I was wonder how I could fix the tail end using either Adobe Photoshop or Adobe Illustrator.
ahhh. ok. well. you need the pen tool to draw the missing part. its such a small part that is missing this will be easy. it will take you less than a minute to add what is missing.
here is an intro video on the pen tool in illustrator.
Adobe Illustrator Basics: Pen Tool Tutorial - YouTube
Or you can email istock and see if they can contact the artist who made it and see if he will do that for you. your choice.
Here is the image
ohh.. its a tiny bit missing. draw it with the pen tool and fill it with black if its in photoshop...
Here's a full version:
A GIS should bring up better versions free or licensed.
So many ways to continue the image.
1. Photoshop:
- Draw the end with a brush and same color. or
- With the Clone stamp tool continue the drawing.
Remember: the tail is a tail you can end it in any ways you want looking at other references.. it is your drawing!
2. Illustrator:
if the image is vector simply add the design with the pen tool or the blob brush.!
is the graphic vector? if so . work in illustrator and draw the rest of the tail. if it was an image, you can rebuild it in photoshop.
I personally think that if its a logo, you would make it in illustrator. but that is me.
I got the stock photo that had the original wolf (the tail is cut off in the original), so I proceeded to image trace it. I'm fairly new to Adobe Illustrator and don't know to much on how to use the app.
If you licensed the image and its incomplete, contact the stock site and see about getting a good copy.
import the jpg file in Illustrator and then select image trace, it will trace that jpg to vector
Is this post in the wrong forum?
Is the stock image raster or vector?
Are you sure you know what the end of its tail should look like?
