We have a single page app and we want to use Adobe Launch to capture every click in a concatenated variable.
In this single concatenated variable, on the click we want to capture "Page Title" and from the element we want to capture | "type=" | "name=" | "id="
The variable will have the following value
prop5="Main Page | checkbox | fund-management | input-menu"
Can this be done in Adobe Launch?
If so, how?
Or is this a job for Processing Rules inside of Adobe Analytics?
This cannot be done thru a processing rule unless all the individual pieces are being sent at the same time. I would suggest using a custom variable, e.g. an array to capture all these values and then send them concatenated prior to when the user navigates away from the page or closes the browser.
Thanks for the reply.
How to you create an array in Launch? It seems that the data elements only allow for single values to be captured in a variable.
Total Likes
There's probably a bunch of ways to do this. Here's one:
With custom code:
This assumes you have a "page_title" date element. If not you could just use:
s.prop5 = document.title + ' | ' + event.target.type + ' | ' + event.target.name + ' | ' + event.target.id;
This just sets the prop. You may also want to fire the beacon here depending on your use case.
