Hi everyone,
I've never posted in here before, but have googled myself crazy and cannot find the solution to my problem anywhere.
I was SO reluctant to update my macbook to High Sierra, but several things just made it necessary. As soon as I started it back up after the update, things started acting weird with photoshop. The most annoying one that I cannot seem to fix is the 'dragging' of the window when I zoom in or out or if I'm looking at two files, whichever file I'm looking at has the second file in the background. I've attached a few pictures. Any suggestions at all would be amazing. This is driving me nuts!
It should not happen, so first thought is to reset preferences.
Hold down cmd-opt-shift, start Photoshop, and Yes to delete the settings file.
Also paste your Photoshop System Info in your reply. Go to help > System Info, click Copy and Cmd v the results if the reset does not work.
That worked! You have saved my sanity!!! Thank you!
I spoke too soon, it's back to doing that. I've tried resetting the settings again and it's not helping.
This is the system info:
Adobe Photoshop Version: 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch]) x64
Operating System: Mac OS 10.13.3
System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2000 MHz
Built-in memory: 8192 MB
Free memory: 3560 MB
Memory available to Photoshop: 6036 MB
Memory used by Photoshop: 70 %
Image tile size: 128K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: False.
OpenGL Crash File: Not Detected.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 INTEL-10.30.14
Video Card Vendor: Intel Inc.
Video Card Renderer: Intel Iris Pro OpenGL Engine
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 900, right: 1440
Video Renderer ID: 16925954
Video Card Memory: 1536 MB
Serial number: 92629285712075769936
Application folder: Macintosh HD:Applications:Adobe Photoshop CS5:
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 233.6G, 29.3G free
Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS5:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
AdobeXMPScript.framework AdobeXMPScript 61.134777 61.134777
adbeape.framework adbeape 3.1.65.7508 61.421986
ICUConverter.framework ICUConverter 3.61 "11" "." "6654"
FileInfo.framework FileInfo 61.134777 61.134777
AdobeCrashReporter.framework AdobeCrashReporter 3.0.20100302
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeACE.framework AdobeACE 2.16.36.10783 64.441628
image_flow.framework AdobeAIF 2.0.00 53.419149
aif_core.framework AdobeAIF 2.0.00 53.419149
PlugPlug.framework PlugPlug 2.0.0.109
aflame.framework AFlame 1.0.38.7511 61.421976
AdobeOwl.framework AdobeOwl 3.0.93 61.433187
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.5.101.7511 61.421978
amtservices.framework 3.0.0.64
AdobeOwlCanvas.framework AdobeOwlCanvas 3.0.68 61.2954
UpdaterNotifications.framework UpdaterNotifications 1.0.0.64 "1.0.0.64"
AdobeExtendScript.framework AdobeExtendScript 4.1.26.11099 61.445301
aflamingo.framework AFlamingo 2.0.402.7511 61.421978
AdobeBIB.framework AdobeBIB 1.2.02.10783 64.441628
AdobeXMPFiles.framework AdobeXMPFiles 61.134777 61.134777
AdobeLinguistic.framework 11696
AdobeAGM.framework AdobeAGM 4.20.69.10783 64.441628
adobe_caps.framework adobe_caps 3.0.116.0 1.201641
dvaadameve.framework dvaadameve 5.0.0.0
adobepdfl.framework AdobePDFL 9.9.0.12130 64.341419
dvacore.framework dvacore 5.0.0.0
AdobePIP.framework AdobePIP 5.0.0.2021
adobepdfsettings.framework AdobePDFSettings 1.4
AlignmentLib.framework xcode 1.0.0.1
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.5.101.7511 61.421978
image_runtime.framework AdobeAIF 2.0.00 53.419149
Cg.framework NVIDIA Cg
AdobeXMP.framework AdobeXMPCore 61.134777 61.134777
adobejp2k.framework AdobeJP2K 2.0.0.12130 64.181312
LogSession.framework LogSession 2.0.1.011
AdobeScCore.framework AdobeScCore 4.1.26.11099 61.445301
wrservices.framework
amtlib.framework amtlib 3.0.0.64
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 64.441628
boost_threads.framework boost_threads 5.0.0.0
AdobeCoolType.framework AdobeCoolType 5.07.83.10783 64.441628
adobe_oobe_launcher.framework 1.0.0.64
AdobeMPS.framework AdobeMPS 5.5.0.12130 64.450375
dvaui.framework dvaui 5.0.0.0
ahclient.framework ahclient 1.5.0.30
asneu.framework AsnEndUser 1.7.0.1
ICUData.framework ICUData 3.61 "11" "." "6654"
aif_ogl.framework AdobeAIF 2.0.00 53.419149
data_flow.framework AdobeAIF 2.0.00 53.419149
Installed plug-ins:
3D Studio 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Angled Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 6.7 (339), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2002-2010 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2003-2010 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 12.0, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1997-2010 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] © 2004-2010 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Entropy 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Extrude 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1990-2010 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Fresco 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 12.0, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 12.0x001 ©2001-2008 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 12.0, Copyright © 2002-2010 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 12.0.2, Copyright © 2002-2010 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 12.0.1, Copyright © 2001-2010 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1990-2010 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1990-2010 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1989-2010 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1989-2010 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1989-2010 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2003-2010 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web & Devices 12.0, Copyright © 1999-2010 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 12.0.2, Copyright © 2010 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1993-2010 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Sumi-e 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 12.0, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “statistics.plugin”
Water Paper 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 12.0, Copyright © 1991-2010 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©2006-2010 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch] ©1989-2010 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 12.0.2, Copyright © 2003-2010 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Plug-ins that failed to load:
Lighting Effects NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “Lighting Effects.plugin”
Send Video Preview to Device NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “FireWire Export.plugin”
Variations NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “Variations.plugin”
Video Preview NO VERSION - 32-bit plug-in not supported in 64-bit - from the file “FireWire Export.plugin”
Flash:
Mini Bridge
Kuler
Access CS Live
CS Review
CS News and Resources
Installed TWAIN devices: NONE
Update to OSX 10.13.4 and see if it resolves the problem.
I've personally noticed performance improvements on my own 2012 MBP
Gene
You are being so helpful, I'm sorry to keep coming back with issues. When I go into help --> updates it tells me it's updated. But it's obviously not. Any idea?
Click the Blue Button to refresh the update list and the 10.13.4 update will show up in the MacOS App Store.
This is all I see...
Not Photoshop Update, MacOS Update.
