Dear all, I tried to zoom in but then the image were tear into pieces,could anyone please help me? I use window 10,I am not sure if this is the main issue? It should look like a leaf rather than something like this...Do you know what went wrong and how to fix it? thanks in advance for your help.
Masako
It
Does turning off »Use Graphics Processor« in the Performance Preferences (Photoshop > Preferences > Performance > Graphic Processor Settings) and restarting Photoshop have any bearing on the issue?
Thank you so much,it works!
Unfortunately this is no proper solution as it invalidates GPU dependent features (like the Rotate View Tool and some Filter acceleration for example) but it indicates problems with the GPU driver or the OS.
5 years later, I had the same problem. Thank you so much it works
